Window won't go up - binding - video
Old Oct 9, 2010 | 04:05 PM
DFOR's Avatar
DFOR
Default Window won't go up - binding - video
My passenger side window is binding up. You can hear it struggling when it gets about a third of the way. Using the window valet, it hits that point, then goes back down. It will go up button on the door, but struggles.
I tried adjusting the window tilt adjustment at the bottom of the door near the hinge. Didn't help. Here is a video showing how it pushes in the door panel as it goes up.
What else can I try? Thanks.
Window Video
Old Oct 9, 2010 | 05:26 PM
JPM's Avatar
JPM
St. Jude Donor '08-'09-'10
Cruise-In IX Veteran
The window is getting caught on the wiring harness which probably broke loose from its contact point on the door which holds it out of the way of the window. Take the door panel off and just re-secure it and you will be good to go.
Old Oct 10, 2010 | 04:02 PM
DFOR's Avatar
DFOR
Thanks John, I'll take the door panel off and see what's going on under there.
To Window won't go up - binding - video
