dic problems
Old Oct 10, 2010 | 05:13 PM
lovethyvette's Avatar
lovethyvette
Default dic problems
the other day my car started going back and fourth from MPH and KPH and then got stuck on KPH. non of my buttons work on the right side of my instrument panel,fuel,trip,reset,temp.i push them and nothing.also driver side climate control doesn't seem to work with the AC on, passenger side cold. and some times when i turn my lights on the dash lights don't come on, i have to keep turning them on and off a few times before they wok. don't know if its all related or not any help would be appreciated before i bring it to the dealer
thanks
Old Oct 10, 2010 | 05:14 PM
99pewtercoupe's Avatar
99pewtercoupe
Dic problems can usually be cured by antibiotics
Old Oct 10, 2010 | 05:29 PM
DaBoz's Avatar
DaBoz
Be careful of erections lasting longer than 4 hours!
Old Oct 10, 2010 | 05:31 PM
lovethyvette
Old Oct 10, 2010 | 05:52 PM
Cocked and Locked's Avatar
Cocked and Locked
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Check for a loose battery connection, most likely on the positive side. If that doesn't work, I'd recommend a Urologist to have a closer inspection of your dic.
Old Oct 10, 2010 | 06:25 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Out of all seriousness it sounds like the GROUND problem - 1st check your battery ground and also make sure your battery is fully charged
Read the Sticky in the TECH section on "ELECTRICAL INFORMATION" there are a few grounds that you are going to need to check to make sure they are working properly.
http://forums.corvetteforum.com/c5-t...tion-long.html
Thanks,Matt
Old Oct 10, 2010 | 07:47 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
"dic problems"
Man, you gotta be careful out there, I hear "some stuff," can kill you .
Old Oct 10, 2010 | 07:59 PM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
I'd be calling all of my buddies and bragging about it.
Old Oct 10, 2010 | 08:07 PM
34RedRage's Avatar
34RedRage
to all the above....
Old Oct 12, 2010 | 02:41 AM
wesz0691's Avatar
wesz0691
This thread might help you with your problems. nothin worse than a dic problem
http://forums.corvetteforum.com/c5-g...s-got-any.html
To dic problems
