active handling light on when...
Old Oct 13, 2010 | 02:03 PM
grandsport6's Avatar
grandsport6
Default active handling light on when...
Hi all, I am looking for some guidance concerning a 2000 coupe I am looking into buying as a daily driver. The traction control light only comes on when the 4 way flashers are activated. There is about a 6 - 10 second delay before it comes on. The owner states that a dealer replaced both the stop lamp and hazard flasher switches and the problem still persists. All exterior lamps function as designed however the head lamp switch will not retract the doors unless it is in the hi beam mode... Two seperate issues here ??? Any suggestions ??? Thanks.
