like this. When your top is down if it squeaks, on the underside of the waterfall are two foam blocks. put a chair leg stick felt pad on each and it stops it. Of course black would be better but this is what I had.
From: "This is not a psychotic episode, but a cleansing moment of clarity."
Well, how does applying felt under your waterfall prevent the top from squeaking when it's in the down and folded position. I'm just trying to make sense of your original post, that's all.
Ah, never mind. I finally figured out what you're trying to say.
Without the weight and pressure of the top sitting on top of the top COVER, the COVER squeaks against the waterfall. Got it.
it actually was making a squeaking type sound because the foam blocks they have with clear plastic over them was just quite not enough to hold against the top frame so these were just the amount needed to hold against the frame better.
