I am having turn signal problems, cant get them to work at all. I replaced the hazard switch about 3 years ago which cured the problem. I also installed corvette enhancements hyperflash harness because I added led tailights afterwards. So, my question is does richards harness completely bypass the turn signal and hazard flashers? My hazards work fine.
No all it does is splice in an electronic flasher relay before the Hazard switch. The original flasher relay is still there and will operate (or should) if the Hyperflash Harness is removed...
It's basically adding another flasher relay earlier into the circuit before the hazard switch and OEM flasher to take over flashing for the OEM unit...
Have you traced the wiring in the Hyperflash Harness and checked to see if you're getting the flasher signal down there? Your Multiswitch on the steering shaft might have bit it...
found the problem. A bad connection at the hyperflash harness. Was going to replace the hyperflash flasher and by moving the wires the flasher started clicking but still no turn signal lights. Wiggle a little more and they started working. Clean and tighten all connections! Talked to richard and he says the hyperflash flasher eliminates the oem flasher for the turn signals but the factory emergency flasher still works. Thanks for the input Tim!
