***Stealth Light Cannons V2 - Most awesome headlights ever! (In Development)
Old 02-03-2011, 09:42 PM
  #141
NorCalVette Kid
NorCalVette Kid's Avatar
St. Jude Donor '09
Originally Posted by theradioflyer
I'll check. There's usually a minimum order on them but i might be able to sneak a set off someone's shelf.
Thanks George that would be killer!! BTW I loves my Light Cannons!
Old 02-03-2011, 10:22 PM
  #142
TheRadioFlyer
Supporting Vendor
TheRadioFlyer's Avatar
Originally Posted by powerjunky
Awww George can I get the Halo's in red please. I know you said White and Orange, but I could put anything else other than red.
Red is an illegal color to have on the front. As the designer and producer of the product i would be legally liable for any legal issues or damages that resulted from that product.
I wanted so bad to do red on my car, but I decided it wasn't worth the risk even for my personal car.
Old 02-03-2011, 10:33 PM
  #143
2Qwik1
Support Corvetteforum!
2Qwik1's Avatar
George,
When I placed my order before you stopped the first GP I opted for the Halos but would definately like the amber halos and definatly with the demon eyes look. If I need to add to the PayPal funds just let me know.
Jim
Old 02-04-2011, 06:24 AM
  #144
VETZILLA
VETZILLA's Avatar
This is possible. I can get the shroud material in Black or white ABS. Either can be painted, but the base color should be picked based on what color the paint will be. For instance: Yellow should be painted on a white shroud and blue would do well on a black shroud.
O.K. I am 100% in on this will need the whole setup with white shroud also want the halo light setup it is just plain cool.e
Where do I send cash an when will they be ready to ship.
M
Old 02-04-2011, 10:37 AM
  #145
TheRadioFlyer
Supporting Vendor
M
I'll put your name on the Priority list. You will receive a PM or Email once the GP starts. I'm planning for the GP to start in 1-2 weeks.
Old 02-04-2011, 10:51 AM
  #146
TheRadioFlyer
Supporting Vendor
Default Radical new option
Here's the latest headlight option I'll be you've never seen:
"Terminator Eyes"
The front of the projector's cutoff shield is what's seen through the lens. By painting the front of the shield, it makes the projector lens appear that color. Installing a red rear-facing red LED will make the projector appear to glow red.... "Terminator eyes"
This type of light is indirect or "refracted" light. MOST states do not have regulation that prohibits this for colors other than white or amber. You should check your local DOT laws if you plan on using a different color. Other suggested colors are blue, red, green, UV(purple)
Option Price: $100
Can be combined with all other options.
Old 02-04-2011, 11:02 AM
  #147
ChromeC5
ChromeC5's Avatar
Whoa! I'm in for the terminator eyes!
Old 02-04-2011, 11:04 AM
  #148
jhiiidoc
jhiiidoc's Avatar
OK...can you give a run-down of all the options and their costs?
This thread had progressed dramatically...
Old 02-04-2011, 12:07 PM
  #149
TheRadioFlyer
Supporting Vendor
Base kit: $1275
Options (add to base price)
Secondary Fog package "A" $120 (for cars that already have foglights)
Secondary Fog Package "B" $250 (for ZO6 cars and others without OEM foglights)
Hyper vision package $250
Halo rings: (white or amber) $150
Demon eyes halo mod: $50 in addition to halo option
Terminator Eyes: $100
Options explained
Secondary Fog light package “A” - (+120) - Convert your inner projector to an auxiliary fog light or rally light using a modified flat cutoff shield and a 3000K HID bulb for a golden-yellow color. Kit “A” comes with a harness to tap power from your OEM fog light circuit. Optionally, you could run a relay harness and install a switch in the cabin (harness and switch not included)
Secondary Fog light package “ZO6” - (+250) Specifically for ZO6 or non-fog light-equipped cars. Includes a Relay harness that taps into thee existing fog light circuit and a GM Fog /trunk switch for the cabin enabling your car to work as though it had fog lights from the factory. No splicing or cutting is required to install this kit.
“Hyper Vision” Package – (+250) The Bad-*** of the headlight world. Features a quad bi-xenon setup where both inner and outer projectors are low and high beams. Nearly 12,000 lumens of output…that’s FIVE TIMES as much output as the stock headlight setup….and with the SLC v2 projector pattern. These are the brightest production headlight for ANY car made.
Halo Rings - (+$150) install CCFL Halo Rings on each projector. Amber or white available. (Taps into your parking lights so you can cruise around in style.
Demon eyes halo mod: $50 in addition to halo option: Paint over the INSIDE of the halo casing showing only 3/4 of the halo ring giving an evil eye appearance. (pictured on the black car with the amber halos above)
Terminator Eyes: $100 By painting the front of the shield, it makes the projector lens appear that color. Installing a red rear-facing red LED will make the projector appear to glow the selected color. Red, Amber, Blue, Green and UV colors available.
Old 02-04-2011, 12:23 PM
  #150
Gitusum
Gitusum's Avatar
Base kit: $1275
i am confused!!!
so i am wanting the base with halo lights . whats the hyper vision package? whats the difference in the demon eyes and terminator eyes? and whats deal with that? you have to paint the cover black or your car color to achieve those looks or are they coming already painted or covered etc from you like that?
Rick
Old 02-04-2011, 12:53 PM
  #151
JuicedZ
JuicedZ's Avatar
terminator looks awesome, nice work
Old 02-04-2011, 12:57 PM
  #152
TheRadioFlyer
Supporting Vendor
Originally Posted by Gitusum
i am confused!!!
Rick
Options explanations posted.
The "demon eyes" is a modification to the halo rings only. you DO NOT need to paint the main lens to get this effect. I just decided I liked the look on my car.
Note: both the main lens and Shroud are paintable but i DO NOT offer a painting service for those parts. You will need to have your body shop do that work if you choose to have them painted.
Old 02-04-2011, 01:01 PM
  #153
ChromeC5
ChromeC5's Avatar
Appears I am down with Hyper Vision with Halo Rings and Terminator Eyes. Sweet.
Question with the Terminator Eyes. Is this something that can be turned on and off individually or do they come on when you turn your lights on?
What base color would you recommend for Pewter?
Old 02-04-2011, 03:35 PM
  #154
TheRadioFlyer
Supporting Vendor
Pewter looks god with black. I can leave the cutoff shield bare metal silver which will reflect the red LED light well, while appearing silver when turned off.
Old 02-06-2011, 03:07 AM
  #155
mountainbiker2
mountainbiker2's Avatar
When you start selling these lights, can you weigh everything we need and let us know what the weight difference is?
thanks,
Steve A.
Old 02-06-2011, 06:21 AM
  #156
SCM_Crash
SCM_Crash's Avatar
HOLY CRAP! The Terminator Eyes look freaking sweet! Too back in my state that's totally illegal. But for a show car, that'd be awesome. Any pics of it with other colors?
Old 02-06-2011, 09:27 AM
  #157
TheRadioFlyer
Supporting Vendor
thanks,
Steve A.
Will do
Not at the moment.
To ***Stealth Light Cannons V2 - Most awesome headlights ever! (In Development)
Old 02-07-2011, 11:35 AM
  #158
ChromeC5
ChromeC5's Avatar
I hate to ask as I feel like I am just pestering you but with the terminator eyes, is this something that turns on with the park lights? Do the lenses look red when the low beams are turned on? Is it possible to have the terminator eyes on an entirely separate switch so they can be turned on and off independently of everything else? If not a totally separate funciton, I may have to pass on them as I do see issues with legality. I am excited about the halos and hyper vision. CAN'T WAIT!
Thank you very much George for the time you have put in with answering our questions. I'm looking forward to the end product and having these lights on my car.
Old 02-07-2011, 12:31 PM
  #159
TheRadioFlyer
Supporting Vendor
Yes, This is the default setting.
No, the low beam overpowers the Red.
Yes this is possible. Alternatively, you can also hook up the Terminator eyes to the high-power positive wire on the turn signal. The terminator eyes would function as the DRL then shut off when the parking lights/headlight were turned on.
Old 02-07-2011, 01:45 PM
  #160
ChromeC5
ChromeC5's Avatar
George, it goes without saying. You are awesome.
Thank you.
Quick Reply: ***Stealth Light Cannons V2 - Most awesome headlights ever! (In Development)
