[Z06] trac control; active handing; abs
Old Oct 20, 2010 | 09:31 AM
HUSKER-Z's Avatar
HUSKER-Z
Default trac control; active handing; abs
Welp, I think my ECBM finally kicked the bucket. The past year it was hit and miss, acting up.... but the last three days it hasn't worked and been getting warnings on start up about it all.
Is there an easy fix for this sumbishh?
thanks! happy weds!
dk
Old Oct 20, 2010 | 10:26 AM
Ranger's Avatar
Ranger
What does the warning in the DIC say?
Ranger
Old Oct 20, 2010 | 10:41 AM
KrispyZ06's Avatar
KrispyZ06
Do you know how to check/ clear your codes?
Old Oct 20, 2010 | 10:45 AM
HUSKER-Z's Avatar
HUSKER-Z
Ranger
it says "service...(all of the above)" one after the other, repectively.
Ranger's Avatar
Ranger
I do. Please respond to my Q in post #2.
HUSKER-Z's Avatar
HUSKER-Z
I am going to try to find out...searching on that right now actually!
Old Oct 20, 2010 | 10:50 AM
Ranger's Avatar
Ranger
Default The Procedure for Checking and Clearing Codes C5
Here is the place to start reading.
First read the stored codes exactly as they show. Write them down, noting whether a code is H or C
Then clear all codes and go for a drive. When you get home. Repeat the code reading and note taking.
Then post the results to this thread.
FYI. Many codes that get set reflect transitory commo issues that don't recur.
Hope this helps.
Ranger
Old Oct 20, 2010 | 10:58 AM
KrispyZ06's Avatar
KrispyZ06
My code check question was aimed at the original poster.
I had this problem about a month ago. I found this post and it helped me greatly.
Originally Posted by pewter99
Link to original sticky regarding Service ABS, Service Traction Control, Service Active Handling and EBCM
http://forums.corvetteforum.com/c5-t...andling-4.html
here are the tutorials in PDF form click and save
Attachment 47653998
Attachment 47653999
If you do indeed need to replace your EBCM I reccomend absfixer.com. I can't reccomend him enough, quick fix, good price and fast turnaround.
Old Oct 20, 2010 | 12:57 PM
HUSKER-Z's Avatar
HUSKER-Z
Wholly bonkers batman.
Here are the codes I pulled:
C1214 HC
B2252
B2282
B2284
U1000H
U1096
Any help would figuring out what these mean, and what could be wrong?
Old Oct 20, 2010 | 01:00 PM
Ranger's Avatar
Ranger
Please state the H and C status of the other codes.
Old Oct 20, 2010 | 02:06 PM
HUSKER-Z's Avatar
HUSKER-Z
sorry, those are all H. I went back out to get lunch, cleared everything, and noticed that the C1214 is the only one that stuck and wouldn't go away...thanks ranger
Old Oct 20, 2010 | 02:26 PM
Ranger's Avatar
Ranger
Narrowed down to that code....
Read: C1214 Sol Valve relay Contact or coil CKT Open start at post #4.
Good luck.
Ranger
To trac control; active handing; abs
