Rearview Mirror Question
Old Oct 20, 2010 | 11:34 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Default Rearview Mirror Question
Is the C5 rearview mirror the same for all models; i.e. Coupe, Vert and FRC/Z06? The reason I'm asking is that my vert mirror has "dome" or map lights underneath that go on automatically whenever I open the door and I was wondering if the C5s with roofs have a different interior lighting setup.
I'm considering a Homelink mirror and was wondering if I would lose those lights underneath that automatically come on whenever I open the door. The website asks for the year/style which is prompting my question.
Thanks!
Old Oct 20, 2010 | 11:46 AM
RJRSW's Avatar
RJRSW
Just to give you another option to consider. I looked into the rearview mirror homelink option and ended up going with the visor instead. Much quicker and easier. Here is a link to my original post:
http://forums.corvetteforum.com/c5-g...home-link.html
Old Oct 20, 2010 | 12:04 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
All of the mirrors, with the exception of the auto dimming mirror are the same for all of the body styles. All of them have the lights under the mirror.
Old Oct 20, 2010 | 12:46 PM
BobAruba's Avatar
BobAruba
The HomeLink sun visor transmitter “implant” is the easiest, most cost effective way to go… and the HomeLink sun visor installed module’s transmitter’s range is stronger too, which will enable you to active your community’s front gate or garage doors from a greater distance.
I don’t know if the rear view mirror’s HomeLink transmitter’s signal is as strong… nor was I able to locate a HomeLink rear view mirror with the transmitter and the two map lights underneath, which I like.
So, to answer your question: I had considered a HomeLink rear view mirror install until I couldn’t locate one with the two map lights… I went the sun visor / HomeLink route and never looked back.
Good luck with your choice.
Bob
Old Oct 20, 2010 | 01:07 PM
MSG C5's Avatar
MSG C5
Bob
Thanks. That's absolutely the type of feedback I was looking for. The Homelink mirrors are pretty cool as some of them other options including rear camera screens, however I plan to add a DD NAV anyway and I could use that screen instead.
My primary concern was losing the two lights underneath the mirror and it sounds as if I will if I go with the Homelink mirror.
Since my OEM mirror has the autodim feature, I also want to hardwire a new radar detector in as well so I think I will investigate the visor option. As part of my interior makeover I'm planning this winter, I plan to get some leather covers for my visors so I will check into that option.
Old Oct 20, 2010 | 02:09 PM
srs244's Avatar
srs244
St. Jude Donor '09 thru '26
To Rearview Mirror Question
