Under hood light madness
Also you know if the hood is open more than 10 minutes the BCM turns off the light. The BCM usually uses the ground to turn things on and off. Try closing the hood and re-opening it.
This little arrangement is a lot more complicated than you'd think-if the load isn't adequate,the light will come on very dimly,or not at all.
Or,if the relay is bad,it won't notify the BCM that it needs power,and the BCM won't ground the relay to turn the light on,and begin the countdown(monitored) to when it turns the power off.
It sounds to me like you may have a bad microrelay.
The only reason I know anything at all about this is from installing an led underhood light,which would only illuminate dimly until I wired a tiny incandescent bulb into the circuit,then the relay would sense adequate load,and tell the BCM to ground the microrelay,which turns the power on,and everything was fine.
I'm not sure how this is going to help the OP,except to point out that there's a lot more to that little light than meets the eye...
If so, something is probably wrong with your BCM/relay. As was said there is always 12 volts at the socket, the BCM grounds the circuit to turn on the light.
Instrument Panel Fuse Block
The instrument panel fuse block is located on the passenger’s side of the vehicle, under the instrument panel and under the toe-board. Remove the carpet and toe-board covering to access the fuse block by lifting up on the latches at the top of each corner of the panel. Then turn the fuse block door **** counterclockwise and pull the door to access the fuses.
Minifuse Usage
1 Console Cigarette Lighter
2 Monitored (Inadvertent) Load Control
3 Lumbar Seat
4 Driver Seat Control Module
5 Radio, Compact Disc Player
6 Parking Lamps, Taillamps
7 Cigarette Lighter
8 Stoplamp, Hazard Flashers
9 Body Control Module
10 Windshield Wiper/Washer
11 Accessory Power
12 Blank
13 Body Control Module - Ignition 1
14 Crank
15 Hazard/Turn Signal
16 Air Bag
17 Tonneau Release
18 HVAC Controls
19 Instrument Panel Control
20 Cruise Control
21 Automatic Transmission Shift Lock Control System and Inside Rearview Mirror
22 Body Control Module - Ignition 3
23 Body Control Module - Ignition 2
24 Radio Antenna
25 Body Control Module - Ignition 1,
26 Hatch/Trunk Release
27 HVAC Controls
28 Bose Speakers
29 Diagnostic
30 Right Door Control Module
31 Power Feed Door Right
32 Fuel Tank Door
33 Door Control Module Left
34 Power Feed Door Left
Circuit Breaker Usage
35 Driver Power Seat
36 Passenger Power Seat
Micro Relay Usage
37 Monitored (Inadvertent) Load Control
38 Right Daytime Running Lamp
39 Hatch/Trunk Release
40 Left Daytime Running Lamp
41 Tonneau Release
42 Courtesy Lamps
43 Automatic Lamp Control Parking Lamps
44 Automatic Lamp Control Headlamps
Mini Relay Usage
45 Bose Speakers
46 Rear Defogger
Maxifuse Usage
47 Ignition 1
48 Rear Defogger
49 Blank
50 Ignition 2
51 Blower Motor
52 Starter
53 Blank
54 Headlamps
