Door Control Module
Old Oct 21, 2010 | 01:13 PM
kasper-pA-'s Avatar
kasper-pA-
St. Jude Donor '05, '14, '15
Default Door Control Module
Hey all,
so my driver side DCM went out yet again (2nd time), first time I replaced the entire DCM with a used one from a '99 - lasted about a month...
Decided I was just going to replace the fuses/relays this time around, found this site (through the forum) http://www.ronjpics.com/Corvettestuff.htm#DCM
But the place he used to get the relays is on backorder, found another site, also on back order.... so my question, is there a local place (I'm in Houston) that may carry these bad boys? Also, am I just unlucky that I've gone through 2 DCM's? or is there a larger problem maybe causing this to happen? No error codes in the DIC other than the DCM ones (they cleared when I replaced it the first time)
another question, how can I raise the window (it's stuck in the down position) with out the DCM?
Ryan
