o2 sensor
Old Oct 28, 2010 | 10:11 AM
Munky's Avatar
Munky
Default o2 sensor
can someone tell me how to get he o2 sensor harness un-clipped from the fender? I am putting my manifolds back on, and don't want to over twist the wires etc. Thanks..... I can't seem to get this darn thing undone.
Old Oct 28, 2010 | 10:22 AM
Tulsa Vette Guy's Avatar
Tulsa Vette Guy
Munky
what type clip or what does it look like,, I have been changing my O2 sensors out,, keep getting a check engine light.
Old Oct 28, 2010 | 10:56 AM
Munky's Avatar
Munky
Originally Posted by Tulsa Vet Guy
Munky
It is a black male female plug that is attached to a gray clip which goes into the fender. I am looking to get the black separated from the gray so i can separate the plugs, and avoid twisting the wires when i re-install into my manifold.
Old Oct 28, 2010 | 08:55 PM
Tulsa Vette Guy
This gray clip should just slide out from the inter fender, look under your hood drivers side and you should see the same clip or one like it that is holding your headlight harness it will be close to the headlight, this way you can see how it is attached to the fender.
To o2 sensor
