dim temp light for a/c display
Old Oct 28, 2010 | 01:32 PM
KUKUSE2000's Avatar
KUKUSE2000
Default dim temp light for a/c display
has anyone had issuses with not being able to see the numbers for mode, etc: on the dash display for a/c control
Old Oct 28, 2010 | 02:10 PM
Vega$Vette's Avatar
Vega$Vette
Do a search. It's an easy DIY fix. Just have to resolder a couple loose connections.
Old Oct 28, 2010 | 03:44 PM
CanyonRunninZ06's Avatar
CanyonRunninZ06
Mine is starting to go. It'll be bright then go dim, couple quick taps and it's bright again. I'll be doing the DIY mod sometime here soon.
Old Oct 28, 2010 | 03:54 PM
Common problem with the Dual Zone HVAC. I've got some files that talk about the repair - if you'd like a copy, just PM me your e-mail address.
Old Oct 28, 2010 | 03:55 PM
rwlc5's Avatar
rwlc5
i found a place that rebuilds the unit. I was having problems with adjusting the temperature beyond a 4 degree range and also turning the unit off. i just sent it off this past Saturday. Should get it back this weekend. I'll post results. The cost was only $45. They also rebuikd speedometers an dother types of electronic units for various make af cars.
Old Oct 28, 2010 | 05:51 PM
v1 rot8's Avatar
v1 rot8
interested in this thread
Old Oct 28, 2010 | 06:31 PM
Nick1's Avatar
Nick1
Right, I think there will be many owners interested in this one, it's such a common problem. It appears that the diy is fairly straight forward, but I note there are warnings that you could damage the circuit board.
From those who have done this, is that true?
Old Oct 28, 2010 | 06:46 PM
Bluefire's Avatar
Bluefire
The fix is re-flowing the solder connections on the (8) current limiting resistors of the LED segment display. The key is don't get the board/components too hot. Ideally, you want a soldering iron at ~600 degrees F. For safety sake, unplug board first.
Apply a small dab of flux to each solder joint.
Apply soldering iron to joint. As soon as the flux vaporizes and the solder melts (approx. 1 - 2 seconds max.), remove the soldering iron. When the solder hardens it should still be relatively shiny.
Clean flux from the solder joints (flux is corrosive) afterwards with alcohol and Q-tip.
Old Oct 28, 2010 | 07:30 PM
JPM's Avatar
JPM
St. Jude Donor '08-'09-'10
Cruise-In IX Veteran
For everyone wanting the fix for the dim HVAC, its very simple.
Remove the center bezel and HVac system.
Remove the control board in the rear of the HVac system
Re-solder the connections I have highlighted below.
Re-install everything and walla ..all fixed.
PM me with any questions
Remove the HVAC
Re-solder the highlighted connections below
Old Oct 28, 2010 | 09:41 PM
KUKUSE2000's Avatar
KUKUSE2000
Thanks everyone seems this to be a common prob. wonder what the root cause was that started it
Old Oct 28, 2010 | 09:42 PM
JPM's Avatar
JPM
Faulty / weak solders
Old Oct 29, 2010 | 02:15 AM
Bluefire's Avatar
Bluefire
Likely the circuit boards were ran through the wave soldering machine at too low of a temprature. This would form cold solder joints. Vibration over the years causes cracks and eventual failure.
That's my scientific wild azz guess.
Old Oct 29, 2010 | 06:26 AM
bassfisher's Avatar
bassfisher
Here are all the details on the repair.
http://forums.corvetteforum.com/c5-t...splay-fix.html
Old Nov 9, 2010 | 03:39 PM
rwlc5's Avatar
rwlc5
An update to my problem. My unit could not be repaired. i had to buy a remanufactured one from a different vendor. The net cost was $120 My problem was not with the dim display. I could not change the temp settings by more than a few degrees and the unit would not always turn off when you pressed the off button. The remanufactured unit works fine.
Old Nov 21, 2010 | 11:20 AM
v1 rot8's Avatar
v1 rot8
Default dim lights fixed
I did mine today. Took about an hour total or less until it was done and the tools put away. Was not a big deal at all, and I am not good with a soldering iron. Anyone on the fence about taking on this job - go for it
Old Nov 21, 2010 | 12:21 PM
tracer1's Avatar
tracer1
Default HVAC resolder
One note on the resistors: Even thought the pictures show 8 resistors (4 in each vertical row), that's not the case with all boards.
Some boards will have 5 resistors in one location & 3 resistors to the bottom right. The latter boards came out supposedly in 2000 but mine was a late model '99 & this was the case. Still, there are 8 resistors (#241) regardless of the board. Sometimes the original solder just needs to be reheated to let the solder flow together again. The fix is easy & usually doesn't take more than an hour total frome removing the bezel & re-installing.
Gregg
To dim temp light for a/c display
