Broken cigarette lighter... advice needed..
Old Oct 28, 2010 | 07:33 PM
Ed2016's Avatar
Ed2016
Default Broken cigarette lighter... advice needed..
The cigarette lighters/accessory outlets on my C5 don't work.
Found out the hard way on a 400 mile trip the other week. Nothing like losing your GPS in the middle of nowhere.
I swapped out both fuses and that didn't help. Any ideas on where to go from here?
I've tried two seperate GPS's and the cigarette lighter - none of them work.
Old Oct 28, 2010 | 08:57 PM
HowlinC5's Avatar
HowlinC5
sounds like a fuse. Check the fuse panel on the passenger side footwell.
Old Oct 28, 2010 | 09:45 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
or check and see if it is not connected in back for some reason.
I ahve about 150 of these lighters if you need another I can send you one
Old Oct 28, 2010 | 09:48 PM
lil vette's Avatar
lil vette
Lot of people disconnect
Old Oct 28, 2010 | 09:51 PM
HowlinC5's Avatar
HowlinC5
I think he said his accessary port doesn't work either. I know what you guys are saying about that cig port, the damn thing falls off of mine all the time.
Old Oct 28, 2010 | 09:52 PM
rrichar2591's Avatar
rrichar2591
I'm assuming if it's the lighter on the dash that you've checked fuse #7 in the footwell. Does the gps work if it's plugged into the lighter in the console area?
Old Oct 28, 2010 | 10:05 PM
Ed2016's Avatar
Ed2016
Already tried changing both fuses with no luck.
I haven't tried the gps on the console area. But I have tried the cigarette letter on the console area one and it didn't work there either.
How can I check to see if its connected on back? Does it unscrew or something simple?
Old Oct 28, 2010 | 10:09 PM
0Double D Mods
Former Vendor
just sorta snaps on is all
if you pull the ash tray section out of the bezel you should maybe be able to reach over with a finger and see if you can feel a connection.
To Broken cigarette lighter... advice needed..
