Putting her away...quick question
Old Oct 31, 2010 | 12:29 PM
ljorges's Avatar
ljorges
Default Putting her away...quick question
Hey guys,
This is most likely the last week for my girl before I put her away for the winter. I've read some of the threads on storage and was just wondering, do some of you guys just start her up 2-3 times a week instead of a battery tender? Would this keep everything working like it should? Is this not a good choice?
I'm keeping her in my garage and not some remote storage area so it's not far from my back door.
Les
Old Oct 31, 2010 | 12:35 PM
moserbe's Avatar
moserbe
Use the battery tender and wait until spring to start it.
Old Oct 31, 2010 | 12:43 PM
99 VET's Avatar
99 VET
Oldtimer
St. Jude Donor '13
I don't believe just starting it up for a short time is a good idea. If you start it you need to drive it for 20 min. or so to get all the fluids warmed up. Suggest using a good battery tender like the Ctek 3300. Drive it when the streets, road are dry & enjoy it when you can!
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Old Oct 31, 2010 | 12:52 PM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
I'm putting mine away this afternoon and it will be in storage until the second or third week in April. I never start mine and do nothing more than disconnect the negative battery terminal. It has fired right up the first time every year for the past 8 years.
Old Oct 31, 2010 | 12:59 PM
killain's Avatar
killain
Oldtimer
Can't wear out if it's not running. Starting it every so often is hard on the engine and related systems. Get a Ctek float charger and look it over in the spring.
Old Oct 31, 2010 | 06:39 PM
Atok's Avatar
Atok
Or a Ctek.
Old Oct 31, 2010 | 07:27 PM
mxdave91's Avatar
mxdave91
I hope I don't hijack but I wanted to ask since we are on the subject. I'm putting my car in a storage facility where there's no power. Should I take my battery out and bring it home to put on a tender for the winter? Also, I unhooked my battery completely when I installed my vararam and three hours later after I hooked it back up I still had all my radio stations and seat memories programed. Is there another source of power that i'm missing? And is it something that we should worry about disconnecting for the winter also?
Old Oct 31, 2010 | 07:36 PM
Must_Have_Z's Avatar
Must_Have_Z
Yes, take the battery out and keep it at home on a tender. This is my 2nd winter with my vette and that's what I do. I don't know the exact answer to your question about the radio/seats, but my car is the same after I re-install the battery in the spring. I'm guessing there is some amount of static ROM memory in the car's computer that keeps these settings even after power is removed? In any event, take that battery out and keep it at home with you!
Old Oct 31, 2010 | 07:45 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
Do a battery tender or unhook the battery, starting it ever few weeks is worse for it unless you intend to actually drive it and get it up to operating temp (ie not let it idle in driveway)
Old Oct 31, 2010 | 11:02 PM
I would use a battery tender rather than just starting it up and letting it run for a few minutes. If you are not going to use a battery tender, you would need to drive it for a while and get everything up to temp.
Old Oct 31, 2010 | 11:10 PM
yaknow's Avatar
yaknow
disconnect it and leave it til spring
Old Nov 1, 2010 | 11:13 AM
ljorges's Avatar
ljorges
Thanks guys!!! I'm gonna look into a batter tender.
Les
To Putting her away...quick question
