03 shocks
Old Nov 8, 2010 | 04:11 PM
TEXASCOUPE's Avatar
TEXASCOUPE
Default 03 shocks
The wifes 03 AE needs shocks. It has the magnetic selective ride option. Any idea how much these run as opposed to standard shocks and is this something I can do myself? Thanks.
Old Nov 8, 2010 | 05:11 PM
dougbfresh's Avatar
dougbfresh
Thousands of $$$-those shocks are GASTLY expensive, check online if your brave.
Old Nov 8, 2010 | 05:33 PM
TEXASCOUPE's Avatar
TEXASCOUPE
I was afraid of that. Corvette tax strikes again!
Old Nov 8, 2010 | 05:39 PM
killain's Avatar
killain
Oldtimer
Default Shocking shocks
If you hunt around you can find a "decent" ? price for the shocks. I don't know why there isn't aftermarket shock for the F55 option.
Old Nov 8, 2010 | 06:48 PM
OneFast1's Avatar
OneFast1
I just paid $400 ea for the front shocks last week. You will have to compress them with tie wraps before you do the install, no problem. Be careful removing the connector at the top of the shocks,push on the spring and they come right off, there is a groove cut at the top of the shock to keep the connector on.
Old Nov 8, 2010 | 08:40 PM
8VETTE7's Avatar
8VETTE7
Here are a couple of recent posts about the magnetic shocks that you might find helpful:
http://forums.corvetteforum.com/c5-g...ic-shocks.html
http://forums.corvetteforum.com/c5-p...-for-sale.html
In the second one the OP has 3 that were still good for sale cheap if you want to stay with the magnetics. If it were me I would ditch the magnetics. 4 new C6Z06 shocks are less expensive than the 3 used magnetic ones but you have to get someone with a Tech II to turn off the F55 per the instructions in the first link.
Old Nov 8, 2010 | 08:59 PM
65GGvert's Avatar
65GGvert
One thing you might check, some owner's think their shocks are bad when the shock stuffers were never removed at delivery. That makes the ride harsh and all that is needed is to pull the covers back and pull out the shipping stuffers.
Old Nov 8, 2010 | 10:20 PM
Aerovette's Avatar
Aerovette
Happened to me.
Who told you, or what indication do you have that they are bad?
Maybe my paranoia or bad history with a few mechanics, but suppose a mechanic needed them for HIS Corvette and YOURS are just what he needs. He sells you new ones and keeps yours. I ain't sayin' Ahm jus' sayin' y'know?
Old Nov 9, 2010 | 04:53 AM
I think I would do that before spending big $$$s on the magnetic shocks.
Sadly, this happens more often than one would think. Worth a look to see if the stuffers are still there.
Old Nov 9, 2010 | 10:05 AM
wascapsfan's Avatar
wascapsfan
Are you sure a 7 year old car needs NEW shocks???
I just replaced my originals on my 99 for c6 shocks but the ones I had were still nearly mint. If they are not leaking and the car can't be bounced when you push on the 4 corners of the car then you are being fleeced.
The option your wife has is a serious upgrade. Make certain that they actually need replacing
Old Nov 9, 2010 | 05:53 PM
TEXASCOUPE's Avatar
TEXASCOUPE
Not positive, but the car has 106k on it. Lots of miles for an 03, but its a driver; definitely not a garage queen. Thats an option; putting Z06 shocks on it instead
Old Nov 9, 2010 | 09:56 PM
striper's Avatar
striper
The magnetic shocks are not going to wear out like conventional shocks. The self-adjusting feature is what also makes them last longer. They do not function like conventional shocks.
Old Nov 10, 2010 | 01:26 AM
8VETTE7's Avatar
8VETTE7
Once they start leaking fluid (they will and do) they are just as done as any conventional shock..........
Old Nov 11, 2010 | 09:24 PM
coajam's Avatar
coajam
I also have a 2003 (recently purchased) with quite a stiff ride. When I took it to the dealer for winterization and the car was up in the hoist I notice the four yellow tabs that indicated to me that the stuffers had not been removed. My wife really loves the ride now. It makes a big difference.
Old Nov 12, 2010 | 09:12 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
Quite a few people with this situation have added the resistors recently and then purchased the C6 Z06 shocks. It is a much lesser expensive alternative! If you're interested in some shocks, let me know!
To 03 shocks
