turn signal issue
Old Nov 8, 2010 | 06:12 PM
showlow's Avatar
showlow
Default turn signal issue
my turn signals and hazard light seem to have a mind of its own. they work when they feel like it. at first i went for the fuse and pulled it out and sandpapered it down. same result. can't seem to find the flasher in the owners manuel. anyone know where it's located ?
Old Nov 8, 2010 | 06:16 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Built into the hazard warning switch. Check out this first post.
http://forums.corvetteforum.com/c5-g...r-located.html
Second link is for the Search feature with a bunch of related posts about this common issue.
http://forums.corvetteforum.com/sear...rchid=20229130
Old Nov 9, 2010 | 01:01 AM
Rebel 1's Avatar
Rebel 1
The emergency/turn signal hazard switch is Not reliable. I used a Tridon electronic flasher part no. EL-12 from Autozone and fixed our turn signals for less than $10.00 and 45 minutes labor. All you remove is the Knee Panel.....
http://forums.corvetteforum.com/1569256474-post50.html
Old Nov 10, 2010 | 08:52 AM
black match box's Avatar
black match box
Default signals
thanks for the info. I think I will try it. black match box
Old Nov 10, 2010 | 09:49 AM
atmsrus1's Avatar
atmsrus1
I had this same issue at one time, drove me nuts. I put switchback LEDs in my clear DRL's from JWMotoring and also installed his hyperflash harness and haven't had the issue since. The hyperflash harness took care of the issue and not the switchbacks....
Old Nov 10, 2010 | 03:43 PM
black match box
spending a little now , will save me headache down the road. thankssssssssssssss for the info. black match box (GINO).
To turn signal issue
