Wind noise in Coupe?
Old Nov 10, 2010 | 11:11 AM
rboineau's Avatar
rboineau
Default Wind noise in Coupe?
Hello, folks. I have a low-mile, garage-kept 2003 Coupe. As soon as I got the car a couple of years ago, I ditched the original run-flats for conventional radials, dropping the noise level inside the car substantially. But there is still a fair amount of noise in the cabin, and it SOUNDS like wind noise from around the hatch.
I freely admit my hearing is not that great anymore, and I know that sounds inside a car can be tricky to locate/identify, but maybe some of you can come back with your opinions and experiences. The hatch gaskets seem to be sealing, as onion-skin paper placed in the channel cannot be moved once the hatch is shut. Perhaps I should weld the hatch shut, or caulk it? (kidding).
Thanks, Ralph Boineau in central South Carolina
Old Nov 10, 2010 | 12:28 PM
Toms02C5's Avatar
Toms02C5
I tend to have a lot of road noise in my coupe as well. I think a lot still comes from tire noise even though I got rid of the Goodyears and went to Michelins. I also get a lot around my targa top even though it seals pretty well.
Mine just tends to be noisy but most seems to come from road noise.
Old Nov 10, 2010 | 12:40 PM
D&A'sDad's Avatar
D&A'sDad
install some headers and B&B Bullets....I promisee the wind noise will go away!!!.......sorry I could not help myself
Old Nov 10, 2010 | 12:49 PM
wilkinru's Avatar
wilkinru
I get a bit of wind noise from the passenger side on my targa. Only an issue going 80 mph+ or when there is a good amount of wind.
Likely not the best seal or the window is not fully coming up - my windows even leak a little if I spray into it just right.
Fix is probably to get a little thicker seal.
Old Nov 10, 2010 | 12:58 PM
Gunny Highway's Avatar
Gunny Highway
Or you could just adjust either the tilt-in angle or how high the window goes up to get a better seal.
Old Nov 10, 2010 | 01:33 PM
memphis_vette's Avatar
memphis_vette
yup, you hit the nail on the head.
adjust the window tip in to get a better seal, you can also adjust the targa top to latch down tighter in the back if needed as well. GL!
Old Nov 10, 2010 | 01:34 PM
Bluefire's Avatar
Bluefire
Check out how the targa top was put on. I have notice over the years I have to be very careful setting the top on. There is a tendency to pinch the weatherstripping at the upper back edge of the side windows. I have heard an air leak twice before and I found the weatherstripping pinched.
Good Luck
Old Nov 10, 2010 | 03:11 PM
DaBoz's Avatar
DaBoz
Put a very light coating of dialectic grease on all the rubber of your top and on the car where it contacts your top. Helps it to seal. It's in your manual and it does work!
Old Nov 11, 2010 | 01:48 AM
Robert 2000's Avatar
Robert 2000
I experience a fair amount of wind noise also. I may have to look into this.
Rob
Old Nov 11, 2010 | 07:39 AM
Most likely the wind noise if coming from the side window area - where the hatch meets the window or the window meets the weatherstripping on the vertical side of the door.
Old Nov 11, 2010 | 09:19 AM
Carcass's Avatar
Carcass
Get a roll of that wide blue painters masking tape,tape over the area that you think is making the noise,and go for a freeway run-If the noise goes away,you've found your leak,now you just need to figure out how to fix it.
Note: While just leaving the tape on WILL work,it is not considered "cool" in some circles.
Old Nov 11, 2010 | 10:27 AM
Jim in Mich's Avatar
Jim in Mich
Adjust the tilt in for the window. It's behind the reflector on the door panel. A little bit goes a long ways.
Old Nov 16, 2012 | 05:48 PM
vete girl's Avatar
vete girl
Default C5 Window Tilt
Does anyone have pics? The window regulator video seems more complicated than it should be. I just want to adjust the tilt
Old Nov 16, 2012 | 08:30 PM
chris308's Avatar
chris308
try this
http://temp.corvetteforum.net/c5/esc...-in_adjust.pdf
Old Nov 16, 2012 | 09:30 PM
allred's Avatar
allred
No kidding! I've always said that GM should have made a coupe with a "fixed" roof, and the removable one as an option......as with the T-Tops of the earlier Camaros/Firebirds.
And I'm not talking about the Z06, which for some unknown reason was not available with auto transmission.
To Wind noise in Coupe?
