18/19 rims
Old Nov 10, 2010 | 01:37 PM
Javi1782's Avatar
Javi1782
Default 18/19 rims
Guys,
I was just offered a great deal on some 18x9 and 19x9.5 wheels. I was planning on going 19/20 setup, I wanted to see if anyone who is running a 18/19 wheel setup can post some pics and let me know what size tires you are running. I am lowered on bolts but I am afaraid that gap will be too large.
Thank you in advanced,
Javi
Old Nov 10, 2010 | 02:43 PM
Munky's Avatar
Munky
Originally Posted by Javi1782
Guys,
Javi
I personally would not go with 18x9 and 19x9.5. Your tire choices will be limited with those wheels. I run 18x9.5 and 19x11. with 275 fronts and 305 rears. I am scared of 19/20 set up due to the reduced sidewall. Do a search on Munky and you should see a couple recent pics of my car.
Old Nov 10, 2010 | 03:19 PM
Neck Breaker's Avatar
Neck Breaker
I had the same question for the 19/20 set up and got a lot of great pictures. Here my link for the 19/20 setup lowered on stock bolts. I have a buddy that's on a 19/19 set up lowered on stock bolts and it looks good. I say his 19/19 and my 19/20 side by side our cars are at the same height almost. Not a big gap at all.
http://forums.corvetteforum.com/c5-g...ock-bolts.html
Old Nov 10, 2010 | 04:55 PM
benjiusn's Avatar
benjiusn
18x9.5 and 19x11 CCW SP500's
Old Nov 10, 2010 | 05:03 PM
Javi1782's Avatar
Javi1782
ben what are you lowered on?
Old Nov 10, 2010 | 08:23 PM
benjiusn's Avatar
benjiusn
Stock bolts only lowered only in the back not quite all the way down. My driveway will not support me lowering the front.
I took a couple more of the wheel well so you can see the gaps.
Rear
Front
Old Nov 10, 2010 | 09:24 PM
Neck Breaker
Originally Posted by benjiusn
Rear
Front
That's not bad at all. I'm 1 3/4 on the back and 1 7/8 on the front lowered all the way on stock bolts with a 19/20 set up.
Old Nov 10, 2010 | 09:34 PM
Neck Breaker
Not the best picture on 19/20 so you can compare the two cars. Only problem I can see is Benjiusn vet is white. With the tires and the gap if you look at it from a distance it looks like there more space. Great to have those measurement pictures. That helps.
BTW clean looking Vert Ben... I lowered my car two weeks ago all the way down and already hate driving it into my drive way. Going to get the fangs in the next couple of weeks.
Old Nov 11, 2010 | 02:26 AM
jpandes's Avatar
jpandes
Here are the two sets of wheels that I have now:
SSR GT-2 18"x9.5" & 19"x10.5"
Lowered on Stock bolts
CCW 505a's 18"x10" & 19"x11.5"
Lowered on Pfadt Coilovers
Tires on both sets of rims are 275/35/18 & 305/30/19
Personally, I prefer the look of the 19"/19" set-up. I would have chosen 19's all-around if I didn't get smokin' deals on my wheels.
My next set of rims will be 19"/19"
Old Nov 11, 2010 | 08:02 AM
Javi1782's Avatar
Javi1782
Thank you all for the pics!!!!!!!!!!!!!
Old Nov 11, 2010 | 08:36 AM
QKSLVR Z's Avatar
QKSLVR Z
Active Streak: 90 Days
i'm running 18x9.5" & 19x11" with 265/35s & 305/30s.. lowered on stock bolts
Old Nov 12, 2010 | 08:29 AM
Javi1782's Avatar
Javi1782
Old Nov 12, 2010 | 08:47 AM
Rans03's Avatar
Rans03
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08
275/35/18 and 305/30/19, wheels are 18x10 & 19x11.5
I prefer the staggard look 18/19 offers.
Old Nov 12, 2010 | 09:36 AM
RSchleder's Avatar
RSchleder
Here's my CCW's, 18 front and 19 rears. Tires are 275x35x18 front and 305x30x19 rear. The 305's stick out a bit from the rear fender that I don't like so I'd do something narrower on the rears if I had a choice.
Old Nov 12, 2010 | 07:28 PM
jamies z06's Avatar
jamies z06
here is my 02 z06 with 19 and 20 black gray scorpions lowered on stock bolts
Old Nov 12, 2010 | 07:37 PM
dbaker's Avatar
dbaker
Here's what I run on my 02Z.....down on stock bolts.
F:275/35/18X9.5
R:295/30/19X10.5
Iforged Senekas
Conti 2 Rubber
It's a standard DD setup.
\db2
carolina
Old Nov 13, 2010 | 03:43 AM
deetee's Avatar
deetee
285/35/18 on 18x8.5 >>>>7/8" gap front
305/30/19 on 19x10>>>>>1.5" gap rear
Old Nov 13, 2010 | 03:48 AM
venomws7's Avatar
venomws7
^^^^ Looks great man.
Old Nov 13, 2010 | 01:06 PM
Javi1782's Avatar
Javi1782
Thank you all for the posts
To 18/19 rims
