im lookin at new wheels, i dont want to run spacers, and i dont want my wheels stickin in/out. i would like a 20/19, or a 19/18 wheel. i would love to do some zr1 spiders in black, but a 12" wide rim wont work?
If you do not want to use spacers, you will need to buy a reproduction wheel. If you order stock C6 GM wheels the offset will be different and you will need spacers.
They make the wheels you want in the correct offset which is I believe 49mm in the front and 56mm in the rear for a C5. I have seen these sizes in the 18" front and 19" rear. Just do a search for reproduction wheels. Also if you order the wheels see if you can get the blank center caps and than order the C5 logo decal. If you don't specify blank caps you will most likely end up with C6 logos.
As I mentioned in my first reply, "I believe that the offset is 49mm front" It maybe 56mm I was not 100% sure. What I was trying to say is make sure what ever wheel you select, that it is a wheel designed for a C5. That way the offset will be correct.
well thats the prob their are lots of wheels that say they are for a c5 with all kinds of different offsets, as in my examples
I purchased my rims from Wheels Botique. They calculated the offset for me. I also purchased a set of Bremo brakes from them, so they spec'ed the rims to fit big brakes as well. I have Vossen rims, 19x9.5 on the front, and 20x11.5 on the rear.
Lol, it does get confusing. I dont know why some wheel companies keep it a secret. If I remember correctly my 19.9.5 and 20x11's are 59mm front and 65mm back, they are going to vary though based on style of the wheel. I like the offsets on mine but I know its was a pain to decide which offset to go with as they were custom made.
thanks alot, im startin to get a good idea of how it works, the wheels im lookin at are 56mm front, and 65mm rear
