Opening headlights??
Old Nov 13, 2010 | 01:23 PM
mel3535's Avatar
mel3535
Default Opening headlights??
Is there a topic here somewhere on how to open up the headlights? Or could someone direct me to somewhere that tells me.I need to pull out my HIDs.
Old Nov 13, 2010 | 01:27 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Turn on/up the headlights, either through the steering wheel switch or taking off the rubber cover and turning them manually in the engine bay. Disconnect the negative battery cable, remove the plastic shrouds (screwdriver) and the light covers (Torx). This will provide you full access to the headlights. Perform whatever work is necessary.
Old Nov 13, 2010 | 05:47 PM
Pretty much covers it.
To Opening headlights??
