another windshield wiper problem
Old Nov 15, 2010 | 08:46 AM
Jharry pope's Avatar
Jharry pope
Default another windshield wiper problem
I recently replaced the wiper motor in my 2000 vette. Now a new problem has arisen. When i put it on intermittent it stops in the middle of the windshield and not in the down posistion. Also, when I turn the wipers off they go down then back up and stop then back down to rest posistion. any clues?
Old Nov 15, 2010 | 11:50 AM
Jistari's Avatar
Jistari
Never did this job but...just a suggestion . ..
Could you not turn the wipers on intermittent
When they stop in the middle of the windshield, turn off the car (not the wipers)
Pull the arms off and put them back on in the bottom position
Turn it back on and test it?
Old Nov 15, 2010 | 12:32 PM
Jharry pope
i will give that a try but what i dont understand is when i turn the switch off the windshield wipers go down, go back up, stop for a second then go back down to the stops. wondering if i have a bad switch
Old Nov 15, 2010 | 12:42 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
That will not work. Your problem is the motor is not properly aligned with the transmission. This thread will explain the whole procedure:
http://forums.corvetteforum.com/c5-t...iper-arms.html
Post #11 shows an excellent picture of the proper alignment in the park position.
I've done this job twice using this procedure, works great.
To another windshield wiper problem
