[Z06] need help
Old Nov 15, 2010 | 03:20 PM
fb420's Avatar
fb420
1st Gear
Default need help
srry if this is in the wrong spot new to this forum i am working on a 01 zo6 I do need this problem solved with the car & to be honest I'm not sure exactly whats wrong I just know its not getting enough fuel, the plugs are burning way lean and it keeps throwing the lean bank 1 and bank 2 codes, could be a manifold leak or some sort of leak thats letting to much air get in, TB ? intake ?
L& S auto said it had been built when they took it apart to redo the heads & put a new clutch in it help please any one
Old Nov 15, 2010 | 03:36 PM
hotwheels57's Avatar
hotwheels57
Probably better placed in the C5 Tech section for future reference.
Do you by any chance have an after market air intake system? If so, check every clamped connection from the throttle body down to the filter assembly. That's the most common source of leaks.
I had one that bugged me for days after I initially installed a "Blackwing" and after market rigid silicone coupler between the throttle body and air bridge. I had intermittent lean codes as well.
It turned out there was a pucker of the rigid silicone couple at the very bottom of the throttle body connection. It was impossible to see without a mirror. It allowed just enough leakage to cause the codes.
Old Nov 15, 2010 | 05:20 PM
TT Z06's Avatar
TT Z06
FI car? Look for physical problems IE: leaking manifold seals Also look at the tune
To need help
