Modification question
Old Nov 15, 2010 | 07:10 PM
Pacific NW C5's Avatar
Pacific NW C5
Default Modification question
Does anyone have any experience with:
"C5 Corvette Rear Bumper Inserts (Stainless Steel)"?
Any input is appreciated.
Old Nov 15, 2010 | 07:17 PM
JPM's Avatar
JPM
St. Jude Donor '08-'09-'10
Cruise-In IX Veteran
Yeah you stick them on the back
Old Nov 15, 2010 | 07:19 PM
DaBoz's Avatar
DaBoz
I've had mine on for 6+ years... I really like them. They finish off the rear of the car. I also have them on the front.
Old Nov 15, 2010 | 07:20 PM
C5Jeff-NJ's Avatar
C5Jeff-NJ
At least give accurate info JPM... you need to peel the protective backing off first, before sticking the letters on...
Old Nov 15, 2010 | 07:23 PM
Cosmic Charlie's Avatar
Cosmic Charlie
SS Inserts here - I like mine
The Rears are flat and lay in nice
The Fronts are flat. except the "V" needs to be bent slightly to fit the curve of the front license plate ...
that's my story & I'm sticking to it
Old Nov 15, 2010 | 07:28 PM
DaBoz's Avatar
DaBoz
Oh yea... forgot about that part... I still catch detailing towels on my "V".
Old Nov 15, 2010 | 07:34 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
Are you referring to these:
If so they are a simple install. Just prep the area where the inserts go with Isopropyl alcohol and then make sure it is good and clean.
Old Nov 15, 2010 | 07:35 PM
jrose7004's Avatar
jrose7004
Hose the area down real good with denatured alcohol.
Old Nov 15, 2010 | 10:48 PM
Easy to install and looks great. Just be sure you properly prepare the area before sticking the letters on.
To Modification question
