[Z06] vararam question
Old Nov 20, 2010 | 04:01 PM
machz800ps's Avatar
machz800ps
Default vararam question
I just bought a vr-b2 from maryland i am in the middle of installing and noticed that i did not get spacers for the ram ducts then noticed the latches are not the rubber t handle type they are the all metal snape type is this a vr-b2 or the vr-b1 the directions say vr-b2 and show rubber t handle type so why are mine the metal ones thought i read on here that the metal ones unsnap i expect when buying something new to be getting the latest design changes if not should be stating that
please help
Steve
Old Nov 20, 2010 | 04:07 PM
machz800ps's Avatar
machz800ps
aslo directions show 6 nuts and bolts holding the 2 ram air ducts together mine has 4
Old Nov 20, 2010 | 04:45 PM
TXGS507's Avatar
TXGS507
No worries.. Mine is the same way... It is the B2..
Old Nov 20, 2010 | 04:55 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Mine only had 4 nutes and bolts holding it also.
Old Nov 20, 2010 | 07:59 PM
machz800ps's Avatar
machz800ps
thanks both you guys !!!!! still want to why the metal clips are on the air box and not the rubber unless im thinking wrong and the metal clips are the updated clip not the rubber clips
One more quest. does the fan shroud get reinstalled directions dont say and i was eye balling it, didnt look like it would fit but not sure??
hope it does dont like the thought of no shroud there, going to finish tomorrow morning
Again thank you guys at least i will be able to sleep tonight
Steve
Old Nov 20, 2010 | 08:04 PM
machz800ps's Avatar
machz800ps
just saw in your pics the shroud is installed
and just read step 17 reinstall shroud im and idiot
Old Nov 20, 2010 | 10:31 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
I have had two VRs and one had metal clips and the other had rubber. No worries with that. The shroud does go in. When you are installing the screws on the front, move the brake cooling ducts out of the way and you will find a nice opening for your 1/4 ratchet to fit!
The first time installing it was a bit of a PITA, but take your time and enjoy it.
Not sure if you got the HALLTECH HONEYCOMB or a screened MAF, so be prepared for codes, unless you get it tuned. I did not tune mine, but I did do the RELEARN, which you can find on the forum with a simple search.
This is a GREAT intake, just do your best to be patient and if you can get a HONEYCOMB from HALLTECH, it is worth the $40!
Micah
Old Nov 21, 2010 | 08:36 AM
machz800ps's Avatar
machz800ps
Micah
Thanks Micah for your help what does the honeycomb due stablize the air going into the maf???
STeve
Old Nov 21, 2010 | 09:54 AM
HT1663WB's Avatar
HT1663WB
Steve,
Mine has the rubber and the right side always comes undone. I purchased the sysytem about 2 years ago as the VRB-2. I would think the metal would be the better set up. My Z is all stock except for the Varram. No tune and no codes.
Good Luck, Bill
Old Nov 21, 2010 | 01:20 PM
machz800ps's Avatar
machz800ps
Originally Posted by HT1663WB
Steve,
Good Luck, Bill
Thanks Bill, Just got back from a 20mile ride did anyone notice a dropin lowend torque?? I just put lg pros, high flow cats and 3'' x pipe on my stock 04 z 2 weeks ago put a about 100miles on it with no codes and had a ton of low end torque 1 and 2 gears broke loose at will, now this morning she ran well with no codes but the torque drop was noticable still torquie but not as much will i get the torque back after a tune or when the car relearns???
car did have a bit of lag to it in 6th gear on the freeway at about 60-65 miles per hour and 1600-1800 rpm im sure its the computer having to relearn just happy i have not thrown any codes with my mods. so far and the car will be getting a tune this spring just hope i dont lose the torque
Steve
Old Nov 21, 2010 | 01:37 PM
HT1663WB's Avatar
HT1663WB
Steve,
To be honest, when I purchased my Z it had a Blackwing air intake on it. I did notice a difference as far as response. The Z felt more responsive with the Blackwing. If I didn't sell the Blackwing I would probably switch back.
Bill
Old Nov 21, 2010 | 08:46 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
STeve
Steve,
The HONEYCOMB regulates the turbulant air and smooths it out as it crosses over the MAF sensors. It really made a big difference and prevented me from having to pay for a tune...which you shouldn't need to add a CAI.
Old Nov 22, 2010 | 10:24 AM
bethunsl's Avatar
bethunsl
The Honeycomb does make a difference. My Z had a vararam on it when I bought it. It had lots of lean codes which didn't seem to go away after a couple of trips to the shop. I read about the honeycomb on the forum,ordered it, and ind installed it. NO MORE CODES!!!
Old Nov 22, 2010 | 09:34 PM
76 VETTE's Avatar
76 VETTE
Old Dec 14, 2010 | 12:33 AM
Z06seal's Avatar
Z06seal
how can a tune get rid of lean codes? you're getting lean codes because the air going through the MAF is turbulent, so it's getting confused and getting odd readings. what tuning can remedy a confused maf reading turbulent reading?
I can get a free tune from a friend, just gotta pay for dyno (70 bux)
should I get the honeycomb, or have him try to get the lean code tuned out on the dyno?
I haven't gotten the thing yet, so I don't even know if I'll get any lean codes
Old Dec 14, 2010 | 12:46 PM
zeevette's Avatar
zeevette
DO NOT use the honeycomb is you are going with a SC. It'll create too much suction, and suck the honeycomb right into your MAF.
To vararam question
