What do YOU recommend for tire pressures?
Old Nov 20, 2010 | 08:41 PM
Jewjenk's Avatar
Jewjenk
No, no, not another one, just run what the sticker says--30 PSI, give or take a couple of pounds. That's all folks...............
Old Nov 20, 2010 | 09:30 PM
vafirevet's Avatar
vafirevet
I run them cold at 30psi all around but have noticed they all bump up to 32-34psi after twenty miles or so of driving.
Old Nov 20, 2010 | 09:56 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Before it really turns ugly.
Old Nov 20, 2010 | 11:52 PM
m6 c5's Avatar
m6 c5
Originally Posted by killain
I am constantly amazed by people who would/will seek a specification or rating seek to find a reason, whether good or bad to ignore certain core values like Motor oils, filters or air pressure in the tires. OK, motor oil and filters could be OK or not. But WHY would you think that GM specified a particular pressure for the from the factory sized tire to be BS ? On my drivers door is a sticker with the size of the OEM tires meant for this vehicle & the air pressure when cold. Why would any rational person think that is somehow corrupt or mistaken? Of all the things worth being discussed, how the heck can a set air pressure be wrong for your car, GM suggests it, the tire manufacturer insists on to keep the particular tire squarely on the road and able to give the longest life. I mean why ?
For the most part this works great but like on my sisters neon it says to run them at 30 psi and the tire is almost flat when only filled to 30 and it definitely shows that they are under-inflated due the the tire wear. In order to get the correct contact patch they need to be inflated to around 40 psi instead, but I would say that is a very uncommon circumstance, but the tire pressure on the door was way off for the fronts but it is dead on for the rears which also are supposed to take 30psi.
Old Nov 21, 2010 | 12:02 AM
99mallett's Avatar
99mallett
From: The line waiting to see Santa Claus stretched all the way back to Terre Haute, and I was at the end, Indiana
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
I have Michelin non-runflats (18's all around), and run 32-34 psi in front, and 30-32 psi in rear. I've tried different pressures, both higher and lower, but this combo seems to be the best all around. The car handles best, and the tires seem to wear evenly (this is my second set of Michelins totaling over 30K miles).
Old Nov 21, 2010 | 12:06 AM
I go by what the manufacturer recommends on the door sticker. For the C5 and my wife's DD, it is 30 psi cold. For my Equinox, it is 30 psi rear and 32 psi front.
Old Nov 21, 2010 | 12:45 AM
SharkByte's Avatar
SharkByte
I normally run 30 PSI in the warmer months and 35 PSI in the winter. Just seems to work for my 04 on stock rims. I'm running sumitomo HTR non-ringlets in stock tire sizes now but I got almost 40k miles out of my original Goodyear Eagle runflats like this...
Old Nov 21, 2010 | 08:42 AM
99 vett babycar's Avatar
99 vett babycar
well said
Old Nov 21, 2010 | 09:28 AM
killain's Avatar
killain
Oldtimer
Default Tire pressures. . .
I don't know a single thing about a Plymouth Neon, so I'm only speaking about a Corvette,
AND, I know there are a great many different "styles" of different tire pressure's for all sorts of tires. IE: super low profile tires on say 20 inch rims or Bigger tires than what the car came with from Bowling Green, and I'm most definitely Not speaking for any custom rim/tire matches as I know the special tires run different pressures. But there was a guy here last year or maybe before who was running his tire at the max pressures, 60 PSI that was marked on the tire. And let's face, you run almost any tire for a Corvette at 60 or higher pressures, the damn things are going to explode if nothing else. Buy the door sticker is for the Goodyear run-flats. I'm just you know kinda surprised by why any one who owns on there car Never looks inside the Owner's Manual ?
If you buy a new dishwasher, you read about how to load it and on what settings are best for you, right ? Then why would question the owner manual for your car. Hell , if you read it and said heck with this, I could see your point. But the air pressure sticker in on the door. Ray Charles could read the damn thing ? Why would you question what the GM endineers and tire manufactures considered the right tire pressure. Rant over ! Thank you for your Patience.
Old Nov 21, 2010 | 10:02 AM
hotwheels57's Avatar
hotwheels57
You have to wonder what the GM engineers were thinking when they included an owners manual with every new car...
Old Nov 21, 2010 | 10:20 AM
Oldvetter's Avatar
Oldvetter
ET, an ex-GM C5 Engineer, recommends 30 psi hot as the "sweet spot". He says the Owner's Manual is a compromise for so many different factors (temperature, type driving, etc.).
I use 28 psi rear and 30 psi front in summer. I use 26 psi rear and 30 psi front for winter. I get about 55,000 miles from front OEM tires and 45,000 miles from rears.
Old Nov 21, 2010 | 10:21 AM
m6 c5's Avatar
m6 c5
I wasnt implying that you were incorrect at all and I guess what I was trying to say was you need to stick to what the manufacturer says unless it is clearly obvious otherwise and as many have stated you get the best tire wear and life out of a tire that is inflated to ~30 psi on the corvette.
Old Nov 21, 2010 | 10:23 AM
  #33
m6 c5's Avatar
m6 c5
Well I may just have take my car for a drive and change the air pressure then if thats what ET said.
Old Nov 21, 2010 | 10:37 AM
  #34
Sunset-C6's Avatar
Sunset-C6
Congrats, finally an intelligent vette owner......
Old Nov 21, 2010 | 01:12 PM
  #35
killain's Avatar
killain
Oldtimer
Default The life and times of a tire . . .
OH Yeah, I understand completely and no offence taken. We're all friends here. And while there's hundreds of tire and wheel combinations, I was only trying to ask why anyone who opened the drivers side door and looked at the sticker, that is the whole and complete answer to any question about OEM/Run-flat tire pressures. But on that same theme, Anyone who opened the owners manual, would have just about and question they might have (And I am sure there's a lot of questions that are not included in the owners manual) But most will be informed/instructed as to what the car was built with and what you might need in case of a breakdown. But that's why we have the after-market vendors who have the education and skill to change things safely. Happy motoring !
Old Nov 21, 2010 | 01:28 PM
  #36
Dope's Avatar
Dope
Resident moron
I run 28 front and rear (cold). Once warmed up they are in the 30-32psi range which is just about right. Most cars I have better luck with ~5psi higher in the front (like my Camaro), but the C5 is so well balanced it seems to like balanced tire pressures as well.
Dope
Old Nov 21, 2010 | 02:00 PM
  #37
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I run 32-35 PSI of pressure - keeps the sensors from getting upset
Thanks,Matt
To What do YOU recommend for tire pressures?
Old Nov 21, 2010 | 02:37 PM
  #38
00Corvette's Avatar
00Corvette
here we go
Old Nov 21, 2010 | 05:09 PM
  #39
m6 c5's Avatar
m6 c5
Yea sometimes it is very hard to believe the pressures that are given in the door but 99% of the time they are dead on(neon being that other 1%) and heck on my camaro it says for high performance driving with speeds exceeding 100 mph it says to consult the owners manual for the correct tire pressures.
I personally like to read through the owners manual when I first get the car to at least look at all the features and how to use them.
Old Nov 21, 2010 | 06:06 PM
  #40
BSE1956's Avatar
BSE1956
Try to keep them at exactly 30psi - depending on ambient temp, the tires will heat up about 2-5 lbs/sq in.
