Leave It In Reverse When Parked...?
Old Nov 29, 2010 | 08:24 AM
  #41
LO PHAT's Avatar
LO PHAT
Originally Posted by Mr.Bill
The reverse thing is a C6 item, But putting your C5 in reverse is a good safety thing to do because reverse is a lower gear and will hold the car better when parked.
LO PHAT
Old Nov 29, 2010 | 08:33 AM
  #42
mundo's Avatar
mundo
Might be some truth to that. C6 Vettes MUST be in reverse when turning off the car. If not the car goes squirly. Maybe the same for C5s.
Old Nov 29, 2010 | 08:54 AM
  #43
Stan MI's Avatar
Stan MI
Originally Posted by kbev
It's in the 2004 C5 manual to leave it in reverse when parking, otherwise there is a battery draw.
I looked for that in the manual (mines an 04). Page 2-35 says to put it in reverse when parking but I don't see any thing about a battery drain if you don't do it.
Is it somewhere else ?????
Old Nov 29, 2010 | 11:51 AM
  #44
mooney201's Avatar
mooney201
Well, this is interesting. I park my C5 in our level garage in neutral, so if I need to move it, I can push it forward or backward. If this putting it into reverse thing to save the battery is true, I will start doing that, but it sure sounds fishy to me.
Old Nov 29, 2010 | 01:03 PM
  #45
TraceZ's Avatar
TraceZ
A car parked with a manual transmission should always be in its lowest gear, reverse, and have the parking brake applied.
A C5 also should be in gear with the clutch pedal pressed while shutting off the engine. This is to prevent the "death rattle" sound coming from the drivetrain when the engine shuts off.
Since the car should be parked in reverse anyhow, the logical thing to do is to put the transmission in R with the clutch pedal depressed, apply the handbrake, shut off the engine and then after the engine stops completely release the clutch pedal and exit the vehicle.
Using the handbrake keeps it servicable and adds safety. If you don't use it, you lose it. It can seize up and potentially leave the car undrivable at some point when some unknowing friend applies it.
Old Nov 30, 2010 | 04:08 PM
  #46
MG RED 99's Avatar
MG RED 99
I agree with this exact procedure except that you apply the e brake after the engine is off and the clutch released so that the car settles against the gears of the trans and not against the e-brake. if you put the e-brake on first the weight of the car will be pushing on the brakes, and most c-5's e-brakes aren't adjusted right anyways, or don't even hold at all. Basically you're saving your e-brake the added wear and tear of having to hold the wieght of the car especially on inclined surfaces
Old Nov 30, 2010 | 04:45 PM
  #47
SCM_Crash's Avatar
SCM_Crash
I didn't know about the e-brake seizing if you don't use it and then suddenly do. I've never NOT used the e-brake, so I guess I wouldn't have that issue, but it's good to know either way.
My dad unfortunately doesn't seem to care about the death rattle since I've heard him turn his car off many times without keeping the clutch in, and he certainly doesn't like parking in R. It's a shame too. I guess one day he'll learn the hard way. Not like these e-brakes are all that reliable.
Old Dec 1, 2010 | 12:37 AM
  #48
JustinStrife's Avatar
JustinStrife
I always left my car in 1st. Interesting.
And my e-brake needs adjusting in the worst way.
