lug wrench and jack?
Old Nov 25, 2010 | 11:19 AM
slimsol's Avatar
slimsol
Default lug wrench and jack?
does c5 come with lug wrench ? i tried to search for one in trunk but couldnt find anything. do i have to go to auto part store to get a lug wrench ?
Old Nov 25, 2010 | 11:26 AM
hotwheels57's Avatar
hotwheels57
It doesn't come with a lug wrench. Instead of the traditional four way lug wrench, I found one made by GORILLA at the local DISCOUNT TIRE. It has two reversible sockets. The telescoping handle collapses so it takes up very little space...
http://www.gorilla-auto.com/power.wrench
Under the "lug nuts" pull down on the website, they have traditional four way and folding four way lug wrenches as well.
As to the jack, I'll assume you want something to carry in the car (?). I found an aluminum scissors jack for my car. It collapses down to about 3 1/2", weighs less than 5# and have a long cranking handle to allow for easy positioning. They came oem on Mazda RX7 and Porsche cars. On EBAY, they run about $25-50. Use keywords "porsche jack" to find more.
This is only to illustrate what I'm referring to. It's not mine...
http://cgi.ebay.com/ebaymotors/Facto...Q5fAccessories
Old Nov 25, 2010 | 11:55 AM
slimsol's Avatar
slimsol
thanks you.
one more question. Where do i put the jack underneath the car? looks like there is very low clearance.
Old Nov 25, 2010 | 11:56 AM
slimsol's Avatar
slimsol
thanks you.
Old Nov 25, 2010 | 12:56 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I carry a small 4 way tire iron with a small scissor jack from a Nissan I think, It takes up very little room in the center cubby of my coupe. I also carry a small air compressor and a plug kit with assorted tools.
Here are jacking points for a C5.
Mr.Bill
Old Nov 25, 2010 | 01:39 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
Mr.Bill
Hey Mr. Bill do you us that small jack on the side points or do you jack it from front or rear cross members?
Old Nov 25, 2010 | 02:03 PM
Mr.Bill's Avatar
Mr.Bill
I haven't had to use it yet, But when the time comes it will be on the side jacking points, With a flat I would never be able to get to the cross member, When I change my oil at home I use a low profile floor jack on the front and rear cross members.
Old Nov 25, 2010 | 02:22 PM
hotwheels57
I've used my scissors jack on the perimeter points w/o a problem. If you're lucky, the scissors jack has a small protrusion that will just fit with minor modifications. Many of the scissors jacks collapse sufficiently to lift from the perimeter. The car will only drop the height of the tire.
If you also carry a portable air compressor (Z06 type or after market), you can add sufficient air into the tire to bring it back up to road height, then place the jack under the cross member(s). Practice doing it so you know if the time comes.
I also carry tire plugs and other tools at all times. Doing so insures that you'll never need them. Not doing so will guarantee you'll wish you had not left the tool bag in the garage/shop for the weekend cruise.
Old Nov 25, 2010 | 03:17 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Do you know if you're still running "run flats?"
Old Nov 25, 2010 | 06:39 PM
Since the car came with runflats from the factory, no lug wrench or jack was provided. No spare provided either.
Old Nov 25, 2010 | 06:51 PM
slimsol's Avatar
slimsol
no. i have aftermarket wheels and tires
Mr.Bill
thanks. i used this diagram. finished taking wheels off and putting em back
Old Nov 25, 2010 | 08:48 PM
99mallett's Avatar
99mallett
From: The line waiting to see Santa Claus stretched all the way back to Terre Haute, and I was at the end, Indiana
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
I carry a cell phone & AAA card.
Old Nov 28, 2010 | 05:37 PM
cuspid's Avatar
cuspid
I carry the traditional cross lug wrench. I hack saw off the the end opposite my lug size so it is a T. Takes up less space.
Old Nov 28, 2010 | 07:54 PM
red oneee's Avatar
red oneee
me tooo
Old Nov 28, 2010 | 10:31 PM
memmer's Avatar
memmer
If you read your roadside service contract most of them say they will in the event of a flat tire change it to your inflated spare tire. Has anyone had a need to test the waters?While I am here I might add that one can and I do carry some of the LEGO type leveling blocks[used for RVs] You can set them up to drive on them even with the flattened tire to get enough clearance to get a jack under the car.I got this idea after I had a flat tire while pulling a utility trailer.I found out i couldn't get the jack under the axle.I was lucky enough to find a rock that I could drive up on and then put the jack under the axle.With the blocks just set them up beside one uf your tires until you get the desired hieghth you want.Just my 2c
To lug wrench and jack?
