Clutch Issues
Old Nov 26, 2010 | 06:11 PM
Sil98vette's Avatar
Sil98vette
Default Clutch Issues
Hi all. I just recently came back from a month long boat boat det. When I took the vette out after not driving it for over a month the clutch seemed extremely light. I don't know if it's just me. My wife's Dad took it out a couple times while I was gone, but he's not really the wild type. What could be causing this issue, if there even is one. I drove her hard today to make sure it wasn't slipping and engaging properly, but everything seems to work. Comments Please!! Thanks
Old Nov 26, 2010 | 06:13 PM
Sil98vette's Avatar
Sil98vette
I also changed the fluid today which had no effect on it.
Old Nov 26, 2010 | 07:51 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
The larger question is if its staying fully engaged while under heavy load...in other words, is it slipping? At what point in pedal travel on the way out, does it fully engage?
Old Nov 29, 2010 | 08:44 AM
mx597turbo's Avatar
mx597turbo
Did you completely bleed the system or just change the fluid in the reservoir?
Old Nov 29, 2010 | 08:04 PM
Sil98vette's Avatar
Sil98vette
I changed the fluid in the reservoir and pumped the clutch 30 times. I opened it back up and the fluid looked good. My dad said the clutch felt pretty stiff to him, but I still think it feels funny. Thanks for the replies
Old Nov 30, 2010 | 01:26 AM
El original's Avatar
El original
How many miles on your Vette? You will know if the clutch is slipping and needs to be replaced when on heavy acceleration you have lots of rpm's and no speed.
Old Nov 30, 2010 | 02:39 PM
mx597turbo's Avatar
mx597turbo
My clutch started feeling like that right before it started slipping badly. I tried the ranger method about 150x, and it didn't help at all. I would say try to bleed the clutch properly. If that doesn't help, it's probably time for a new clutch.
Old Nov 30, 2010 | 09:14 PM
Sil98vette's Avatar
Sil98vette
The vette has 28k. I don't think it's slipping yet. Ugh that doesn't sound good mx597turbo. I will try and do a proper bleed this weekend, maybe start shopping around for a new clutch
Old Nov 30, 2010 | 09:44 PM
johnson-rod's Avatar
johnson-rod
After not driving mine for a few weeks my slave cylinder started leaking. I dragged it around all winter like that but in the spring I had to bite the bullet and change the slave.
My clutch was fine so I just did the slave and saved a day of labor and around $600.
Hope the fluid change fixes it for ya.
Old Nov 30, 2010 | 11:59 PM
Sil98vette's Avatar
Sil98vette
Thanks for the tip Johnson-rod.
Old Dec 1, 2010 | 07:34 PM
mx597turbo's Avatar
mx597turbo
How did you save labor? Once the slave is accessible, it takes maybe another 30 minutes to swap in a new clutch.
Old Dec 1, 2010 | 09:28 PM
johnson-rod
30 minutes?
I'll call you next time.
It looked like another day of knuckle busting-dirt in the eye screwing around on my back. The $600 is the cost of the new clutch, pressure plate and flywheel kit. BTW-you also get to change the pilot bearing since you are in there. Too much fun for me.
There was nothing wrong with the clutch then and a year later there still isn't.
Old Dec 4, 2010 | 11:24 AM
mx597turbo's Avatar
mx597turbo
30 minutes?
No problem. Honestly, the swapping the actual clutch is the one of the easiest parts of the clutch job as a whole.
Old Dec 4, 2010 | 02:42 PM
Ranger's Avatar
Ranger
I have a different suggestion. Just swap the content of the reservoir right after the next 5-10 times you drive the car. Use DOT4 brake fluid such as Prestone. Total cost is about $6. I'd sure do that before further steps and $$$.
At 28K on the OD with stock power, clutch itself and actuator (slave) should be fine. If the fluid has not been maintained, cleaning that up is the first step. The reservoir is the easiest path. A "full bleed" is cumbersome, expensive if a dealer does it, and it will not rid the pockets of accumulated crud that follow lack of fluid maintenance. Also the dealer will usually introduce air into the hydraulics during the "full bleed." Another headache to get rid of that.
Changes in pedal feel usually stem from corrupt fluid or master cylinder seals that are abraded by clutch dust accumulation in the hydraulics. You can easily change the master cylinder, should that prove a necessary second step, for $125 or less in parts and an hour's labor, more or less.
Ranger
Old Dec 4, 2010 | 03:01 PM
Sil98vette's Avatar
Sil98vette
I'll give it a shot. Thanks Ranger
Old Dec 4, 2010 | 03:25 PM
Ranger's Avatar
Ranger
Hate seeing anyone spend discretionary $$$ prematurely, least of all our serving defenders of America, like Sil98vette.
Please let me know how it turns out.
Ranger
Old Dec 4, 2010 | 11:14 PM
Sil98vette's Avatar
Sil98vette
Will do. Thanks ranger
To Clutch Issues
