[Z06] Z06 Auto Conversion Wiring
You'll need to add a harness in the engine compartment (RPM Transmission) sells them.
You'll have to re-pin the PCM harness, re-flash the PCM and whole host of other little stuff.
You'll need to weld a bracket in the tunnel for the shifter cable.
Adapter Plate between the transmission and differential.
Run Cooler lines and tranny cooler.
Auto Pedal / Switches to make everything work.
Best bet is to buy a set of manuals for year car and read thru the schematics.
I ended up calling RPM, they were a big help on the wiring. I know its not just a plug n play swap but I am very familiar with vettes and ls conversions and have built quite a few from the ground up. I also have the whole donor auto C5 to use for any thing I need. I have done many LS conversions into many other cars so I do not think making a Z06 an auto will be very hard compared to a full ls conversion from scratch.
I've done a few both ways now. Mechanics are pretty straight forward, it's sorting out the wiring to make sure everything works correctly.
