Lowering?
Nov 30, 2010 | 02:36 AM
Lowering?
Where do I buy longer bolts? Can someone direct me to someone that sells these? And how do I replace the stock bolts with longer ones?
Nov 30, 2010 | 03:04 AM
St. Jude Donor '08
Nov 30, 2010 | 04:24 PM
is that a normal price for the lowering kit?
Nov 30, 2010 | 04:28 PM
St. Jude Donor '05, '12-'13, '15-'16, '21
Nov 30, 2010 | 06:11 PM
From: Wylie TX --> Less is More, except under the hood !
$40 at Zip Corvette
This kit uses the existing rear bushings. Many people use this kit, and on here you will hear people refer to it as the "ZIP Kit".
Go to:
http://www.zip-corvette.com/ProductD...L2-SR&CTitle=&
Nov 30, 2010 | 07:00 PM
Quote:
Originally Posted by
Toque
Any info on how to replace the stock bolts with the aftermarket one?Is it "hard"?
Nov 30, 2010 | 07:04 PM
jack up your car take a wheel off and look? its not hard
tighten the rear, loosen the front
Nov 30, 2010 | 08:27 PM
Nov 30, 2010 | 08:51 PM
i would just use stock bolts, i used longer bolts in the rear, and its too low. im going to put the stockers back in..... the front is too low, on stock bolts
Dec 1, 2010 | 06:55 PM
mel3535
The rear's are super easy.
The fronts are a little tricky. You will see once you get in there...
Toque
