Can anyone tell me what this code is? It is on a buddy of mines 02 Z and we already changed a hub we thought was bad but the ABS light is still on...Don't want to buy another unnecessary part.....
Thank you
Sorry, the code is C1214, not sure if that makes a difference,
Thank you
Reason: Change Code
I just replaced mine, had a C1232 code and Brandon at Abs fixer said mine was wasted. So I bought a new one, cleared the codes and away I go. So far so good. By the way a lighting surge got mine through my battery tender (and fried the tender also). If it comes a storm unplug that battery tender or get a good surge protector.
Thank you
Thank you
Not sure why you would have changed a hub when you had this code pointing you in a different direction.
Before you replace or repair the EBCM you should follow the diagnostic procedure for this code and verify the EBCM is the problem instead of something wrong with the wiring, pump motor voltage supply to the EBCM or the pump motor ground.
Bill
