wheel adapters
I have an 03.. I just put on a set of 09 wheels and they are close to the inner wheel well, so i tried a set of 6mm spacers with plain lug nuts with out the chrome cap (stock GM) to see how many threads were caught; almost 6 threads that's not cool what can i do? Should i change the studs to longer ones. I would recommend that all you corvette owners with spacers to check yours as well.
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
St. Jude Donor '11-'12-'13-'14-'15
Personally... Since our cars are hub centric, I would get hub and wheel centric spacers if they make em in 6mm. The place I got mine custom makes each one so I think they can do it...
I'm using 12mm front and 13mm in the rear hub and wheel centric spacers with 1/2" longer studs AND ET lug nuts. I track mine so I wanted it beefed up a tad...
Tim
Tim
