Help with depo question
Old Dec 7, 2010 | 08:08 PM
LSOHOLIC's Avatar
LSOHOLIC
Default Help with depo question
Ok, I've removed my original headlights. The question is about the bracket the motor mounts to. Is it need for a depo's to mount to or anything like that ?? Or can the bracket be removed ??
THANKS....
Old Dec 8, 2010 | 07:48 AM
Quik Z06's Avatar
0Quik Z06
Former Vendor
You wouldn't need the bracket for the motor to mount to as the Depo's should come with brackets that you use to mount them to the car.
Old Dec 8, 2010 | 12:14 PM
VETSTYL's Avatar
VETSTYL
Default Brackets
The depos come with its own mounting hardware You won't use anything from the OEM lights except the connection.
To Help with depo question
