LS Stroker Kits?
Old Dec 8, 2010 | 04:15 PM
Dominic Toretto's Avatar
Dominic Toretto
Default LS Stroker Kits?
What displacement increasements are available for the LS1/2/3 engines in regards to a forged bottom end? Not considering boring the cylinders.
-Alex
Old Dec 8, 2010 | 04:24 PM
Robert 2000's Avatar
Robert 2000
Old Dec 8, 2010 | 04:37 PM
m6 c5's Avatar
m6 c5
Old Dec 8, 2010 | 05:49 PM
blackmachdown's Avatar
blackmachdown
upto 454 if you go with an lsx
Old Dec 8, 2010 | 06:22 PM
HowlinC5's Avatar
HowlinC5
My friends have done alot with their LS engines and everyone that went forged just went with either an LS2 or LS7 block. I know a guy running 950 whp with an LS2 block and a stock LS6 manifold and throttle body. The key is his 91mm Turbo. If you want to go all motor stroker is the way to go but I have not seen or heard of anyone stroking an LS motor.
I do know that you can get LS2 blocks in a 402CI
Old Dec 8, 2010 | 07:41 PM
zeevette's Avatar
zeevette
Yeah, that LS2 402 IS stroked, to 4". This is standard stroke for a 427, too. Also gives you 382CI on a stock bore LS1-6.
Old Dec 8, 2010 | 08:29 PM
TriplBlk's Avatar
TriplBlk
Old Dec 8, 2010 | 09:00 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
LS1 382/383
LS2 402
LS3 416
Go for the LS3 416 will be a real TQ monster
Old Dec 9, 2010 | 11:49 AM
Dominic Toretto
Bump
-Alex
Old Dec 9, 2010 | 12:55 PM
Vector's Avatar
Vector
Might want to talk to the folks at 21st Century Muscle Car in Carrolton, TX. I had the following done there severals years ago and am very happy with the results!
LPE LS2 Stroker - 403 cid , HD A4 w/ 3.42, Yank/LPE 3200 TC, BBP Vortex Cold Air, 90mm Ported TB and FAST Intake, 1 7/8 Kook Long Tube Headers, B&B Tri Flow Exhaust
Old Dec 9, 2010 | 04:12 PM
Dominic Toretto
Got a dyno sheet there Vector?
-Alex
Old Dec 9, 2010 | 05:56 PM
Vector's Avatar
Vector
-Alex
Yes, but my scanner is down - it showed 458 RWHP and, 438 RWTQ . I have the mildest of the three cams they can put in this setup. Not like some of the monster forced induction motors but strong and lots of torque - about 80% of maximum torque at 2500 RPM's.
Old Dec 10, 2010 | 09:24 AM
Dominic Toretto
Very nice there! That's about the output of a C6ZO6. Do you remember what bottom end parts are in there?
-Alex
Old Dec 10, 2010 | 09:37 AM
Vector's Avatar
Vector
• Callies 4.000" stroke forged steel crankshaft
• JE 4.005" forged aluminum pistons
• Manley 6.125" fully machined, 4340 forged steel connecting rods
• Computer balanced and blueprinted
• Lingenfelter CNC ported & polished LS2 cylinder heads
• 2.055" / 1.57" one piece stainless steel intake & exhaust valves
• Three angle valve job, hand blending of valve seats
• CC chambers, surface, set spring heights and assembly
• Heavy duty dual valve springs, titanium retainers, 10 degree locks, valve seals and HD pushrods
• 21 CMC hydraulic roller camshaft
• High volume oil pump assembly
• Ported & polished throttle body
Straight from their web page. And for the record the C6Z06's don't do well next to mine at the 1/4 mile track.
Old Dec 10, 2010 | 12:50 PM
Dominic Toretto
"So much torque, the chassis twisted coming off the line."
Shameless F&F plug lol.
Anywho, man I love the setup you are running there. That's about exactly what I want. I am guessing this is a weekend toy correct?
How is it in traffic?
Can I ask how much that setup runs, plus the tune?
What's the maintenance like?
How many miles on that setup?
-Alex
Old Dec 10, 2010 | 12:51 PM
Dominic Toretto
Also what transmission and rear end are you using?
-Alex
Old Dec 10, 2010 | 01:27 PM
Vector's Avatar
Vector
Alex, you have a meesage.
To LS Stroker Kits?
