Axle/Diff oil
Old Dec 9, 2010 | 05:28 AM
Z06seal's Avatar
Z06seal
Default Axle/Diff oil
What oil is recommended for the rear diff/axle (transaxle?) for my Z06?
Is the Mobil 1 synth gear oil any good? Would I need to put additives for that one? It's the "LS" one so I suppose it has the additive already?
Mobil1 Synthetic Gear Lubricant LS 75W-90
apparently redline recommends their 75w90 for the Z06 as it already has the additives in it.
oh and I don't have a manual, but he states that the manual says no WOT for 300 miles after changing diff fluid? is that true? kind of hard to do in my Z06, but I'll try my best
oh, and how much? 1 quart? 2 quarts?
Thanks!
Old Dec 9, 2010 | 06:28 AM
Corvette Don's Avatar
Corvette Don
Never heard of the 300 mile "break in" after a fluid change. I use Royal Purple, it already has the correct amount of LS additive in it but I am pretty sure the Mobil 1 LS is the right stuff. Its about 1.7-1.9 Qts to fill it.
Old Dec 9, 2010 | 07:59 AM
Z06seal's Avatar
Z06seal
Thanks bud.
Anyone know for sure about the mobil 1 ls having the additive? I suppose it does since it's 'ls'
And the 300 mile no wot is in the manual. Don't have a manual to verify. Some people say it's unnecessary and few figure 8s will do the trick.
spdislife's Avatar
spdislife
I use Mobil 1 with the GM additive...never heard of this breakin period.
Old Dec 9, 2010 | 09:32 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Mobil 1 LS has the limited slip additive blended in it. No additional limited slip additive is normally needed.
Old Dec 9, 2010 | 12:11 PM
Z06seal's Avatar
Z06seal
Thanks quick silver.
I wish I had a manual to forward you guys the page number.
Old Dec 9, 2010 | 12:13 PM
Quicksilver Vert 01
I've seen that precaution in my manual too.
You can download an owner's manual here: http://gmpartshouse.com/
Click on downloads, and select your model year.
Old Dec 9, 2010 | 12:25 PM
LoneStarFRC's Avatar
LoneStarFRC
Amsoil Severe Gear (SVG) 75W-90
No additive needed.
/thread
Old Dec 9, 2010 | 12:31 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Yes Mobil 1 is fine to use, I changed out the factory in our C6 to this and no issues
Old Dec 9, 2010 | 01:10 PM
02*C5's Avatar
02*C5
I have done a few diff lube changes and never heard about the 300 mile rule. Hell once I did the diff oil change drove to the track and knocked off a 125mph trap and no issues.
Old Dec 9, 2010 | 01:18 PM
kh400's Avatar
kh400
Originally Posted by Z06seal
Thanks bud.
Mobil one synthetic gear lube is great, but cost @$20/qt. Walmart has a synthetic 90w gear lube with the same specs for $5/qt. Something to think about.
Old Dec 9, 2010 | 06:39 PM
Z06seal's Avatar
Z06seal
wow! I got mine for 11 bux a quart lol (at advance)
Old Dec 10, 2010 | 08:34 AM
Quicksilver Vert 01
C5 Corvettes require 75W-90 synthetic gear lube.
90W is a straight grade gear oil, which doesn't meet the spec.
To Axle/Diff oil
