i had the same 'why's it doing that' thoughts originally too. but as mentioned previously, it is on for a reason, and it does shut off if conditions warrant it. mine has shut off, and come back on later if the moisture content in the cabin increases.
something to try, if i remember correctly, when you are trying to turn the a/c off in auto mode, i think if the air is in the recirculating mode it won't turn off because you can't use recirc. with anything other than a/c. if you switch the air flow to outside air you can turn the a/c off. [i think]
of course the air compressor will always be on in defrost mode.
Yup, DL'd the copy of the manual and that's what it says. it makes sense and maybe that's what it was. I'm gonna check next time
Following is from the Owner's Manual, as I said before I think the set point for the A/C not to operate is about 38 F outside temperature:
"The air conditioning
does not operate at temperatures below approximately
35°F to 40°F (2°C to 4°C). If the system is operating in
the AUTO mode, turning the air conditioning off will
delete AUTO from the digital display and show current
mode and fan settings. The AUTO button must be
pressed to return to the automatic mode operation."
This is a protection to prevent the A/C from freezing, plus defrosting (or should I say dehumidifying) isn't really needed when outside temperature approaches the freezing point.
Has anyone, who drives in cold wther(a rarity, I know), use the AUTO funtion and ever have the A/C light go off?, or, is the A/C light always on when AUTO is used?
Has anyone, who drives in cold weather(a rarity, I know), use the AUTO funtion and ever have the A/C light go off?, or, is the A/C light always on when AUTO is used?
It does whatever it pleases. I no longer try to figure it out. It is usually pretty much what I would have done anyway.
