lifting points
Old Dec 9, 2010 | 11:26 PM
Arizona Jim's Avatar
Arizona Jim
Default lifting points
Question: Per the owners manual (2004, pages 5-73 and 5-74) there are points located on the front and the rear suspension for lifting the car. Why does everyone lift on the frame rails? I used the locations on the front suspension to get at the drain plug and then lowered the car while the oil drained out. I had the tire shop use these 4 lift points to raise the car when I had new tires put on. Or am I not reading the manual correctly.
Old Dec 9, 2010 | 11:32 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
You need to NEVER lift your car near the rocker panels. The jacking points require pucks to lift the car safely! Do a search, there is ton's of advice on this subject.
Old Dec 9, 2010 | 11:35 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Here is the lifting points on a C5.
Mr.Bill
Old Dec 9, 2010 | 11:38 PM
Arizona Jim
Yes there is and they all talk about using pucks at the points where the body panels wrap around the frame. You put them in the cut out areas so that you lift on the frame and not on the body panels.
The lift points described in the manual are way inside the under body on the cast aluminum supension members. I see no need for pucks at these locations.
Old Dec 9, 2010 | 11:42 PM
Arizona Jim
Mr. Bill,
If I read the grid chart correctly I think I'm talking about locations number 1. These are what is depicted in my owners manual. Why not use these locations and not mess with pucks?
Old Dec 9, 2010 | 11:50 PM
Mr.Bill's Avatar
Mr.Bill
Originally Posted by Arizona Jim
Mr. Bill,
I myself use the #1 also, I have never lifted my car from the side, I don't even own a set of pucks.
Old Dec 9, 2010 | 11:55 PM
Arizona Jim
Mr. Bill,
Thanks for the reinforcement of how I've been doing it. I can sleep soundly tonight
Az Jim
Old Dec 10, 2010 | 01:20 AM
UM Rebel's Avatar
UM Rebel
Here's where the crooks lifted mine.
Old Dec 10, 2010 | 11:12 AM
skyavonee's Avatar
skyavonee
Mr. Bill,
It's difficult to reach the front preferred location, even with a low profile jack (and if your car is lowered I'm guessing you can completely forget about it). If you have pucks, you can reach the optional locations with any old regular jack.
Old Dec 10, 2010 | 11:39 AM
Mr.Bill's Avatar
Mr.Bill
never an issue for my low profile jack to get under the front.
Old Dec 10, 2010 | 11:47 AM
Stan MI's Avatar
Stan MI
I could probably do a search on this but then noone could post and tell me to.
Is there a video anywhere that shows exactly how lifting should be done? Seems like I see this type of question all the time. Maybe if someone could point to a video of proper technique it might be of additional help.
JMT's
Old Apr 17, 2013 | 10:33 AM
Zora's Brother Joe's Avatar
Zora's Brother Joe
I have a 4 post above ground lift, my car has not been lowered, before trying to lift the car will my arms clear or will I need to use a jack for sufficent clearance ?
Old Apr 17, 2013 | 10:55 AM
Loc's Avatar
Loc
This is a great pic. Now I can show my wife why landscaping could be a bad thing. If they didn't have the blocks you may have been ok. Sorry about your car.
I have the full length aluminum frame rails and use those to jack. Never had a problem.
Old Apr 17, 2013 | 11:22 AM
I use jacking pucks and lift from the side for the fronts simply because my floor jack won't go under the front of the car and reach the lifting point there. For the back, it works just fine lifting in the preferred locations.
Old Apr 17, 2013 | 11:37 AM
Zora's Brother Joe
I have a above ground lift , which is two post , with the 4 swing arms do I need lift pucks ? or can I just use the rubber pads on the lift arms and raise it on the 4 lift points in the diagram ? , Someone has done the same thing , I just don't want to damage the car .
To lifting points
