ctek connection to optima red top
Old Dec 11, 2010 | 02:19 PM
2001zee5's Avatar
2001zee5
2nd Gear
Default ctek connection to optima red top
looking for connection help /advice. CTEK 3600 connection to Optima red top battery with side terminals only. The clamps will slip off the small battery conection bolt,the ring terminal connection is to small for the bolt and will not clear the water tight seal on the battery case . Does anyone have solution to this connection problem.
Old Dec 11, 2010 | 03:00 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I have the CTEK US 3300 and all I use are the clamps, Never an issue for me, Summit Racing sells an attachment that plugs on the ctek and then you plug it into your 12 volt lighter/power point.
Old Dec 11, 2010 | 03:44 PM
Jistari's Avatar
Jistari
Or alternately, replace the screw in terminals with the ones with threaded tips (get them right in the local autoparts store) and permanently attach the ring lugs that came with the CTek there.
[IMG][/IMG]
Since this pic I have lengthened that lead there and have the plug tucked down into the cove (dont even have to open the hood to hook it up now )
Old Dec 11, 2010 | 03:45 PM
99 VET's Avatar
99 VET
Oldtimer
St. Jude Donor '13
Suggest you get the "Ctek Comfort Connect" it plugs into a power outlet like the lighter. Just got mine from Chip...Good luck!
Old Dec 12, 2010 | 12:02 PM
2001zee5's Avatar
2001zee5
2nd Gear
Thanks for the help guys, I am going to go with the extended bolts as shown in Jistari's reply
Old Dec 12, 2010 | 12:18 PM
hotwheels57's Avatar
hotwheels57
Change the ring terminals is simple and cheap. Find them at RADIO SHACK, ACE HARDWARE or TRUE VALUE.
Mark + and - with red/black paint or red/black shrink tubing. Change them one at a time so you don't confuse positive from negative.
Old Sep 7, 2013 | 05:02 PM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
St. Jude Contributor
I know this is an old thread, but I finally did the "bolt extender" trick so I could permanently mount the eyelets for my CTEK. Used a little velcro to keep the connector in place when not on the charger and driving around.
Old Sep 7, 2013 | 05:44 PM
Big Duk's Avatar
Big Duk
Blue top = problem solved.
To ctek connection to optima red top
