How do I adjust a 69 throttle cable?
Old Dec 13, 2010 | 12:17 AM
tacoamerica's Avatar
tacoamerica
Default How do I adjust a 69 throttle cable?
I just installed a new accelerator pedal lever (68-69E has a separate bolt-on piece to the pedal rod, that the cable hooks up to). I have a 69 L46-350/350, 4sp, ac, ps/pb with a Q-Jet #7029207, newly rebuilt and runs perfect, then the old lever broke. I know the lever was bending because I was increasingly losing speed and pedal travel over the past year, then it just cracked.
Can someone please tell me a basic procedure I can follow to be sure I get the total stroke out of the pedal, from idle to full tilt boogie? Note: I put an adjustable stop on the lever end of the cable (same as what's used on the hood release cable), so I can adjust the length of the cable.
Thanks in advance, Taco
Old Dec 13, 2010 | 12:30 AM
99alvette's Avatar
99alvette
Wrong forum this is the C5 forum try the C3 Forum http://forums.corvetteforum.com/c3-general-119/
Old Dec 13, 2010 | 01:13 AM
tacoamerica
Sorry, just now posted it in C3.
To How do I adjust a 69 throttle cable?
