When I hook up the Ctek3300 to my Optima redtop the maintenance charge indicator (full battery symbol) lights up green and the charge indicator (partial battery symbol) flashes orange. The instructions don't address both lights on at the same time. As I read the instructions one or the other lights up or flashes, not both at the same time. Do I have a problem or is this normal when charging? I've attached the negative cable to the chassis so I think I've got a good ground.
