head lights
Old Dec 20, 2010 | 03:08 PM
black match box's Avatar
black match box
Default head lights
my question is, when I start up my vette and put it in reverse the head lights go up?, only in reverse as soon as I put it in first gear they will go down, after I start moving, but if Im in the garage and put in reverse they will go up, even if I put in (n) and work the light switch to on and off they will stay on untill I shut it off. is this normal or is there something wrong ?, my 67 and my 76 did not do that , puzzeled, this is a 2000 coupe 6 speed. t/u black match box (GINO)
Old Dec 20, 2010 | 03:13 PM
99alvette's Avatar
99alvette
U got somthing wrong sounds like some crossed wires maybe ur reverse lights are some how wired into the headlights???
Old Dec 20, 2010 | 03:21 PM
65GGvert's Avatar
65GGvert
Try disabling the twilight sentinel in the DIC if you have that option, and see what the lights do then.
Old Dec 20, 2010 | 03:52 PM
oh1vette's Avatar
oh1vette
Old Dec 20, 2010 | 04:45 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
if that works, more likely than not you have something amiss with the wiring to your e-brake as the twilight sentinel doesn't kick in until you release the hand brake regardless of the gear the shifter may be positioned in (with the clutch engaged or disengaged). i have my sentinel active and i can sit in the garage in the dead of night forever and the headlights don't pop up until i release the e brake.
Old Dec 21, 2010 | 05:35 AM
That's where I would look first.
Old Dec 21, 2010 | 07:57 AM
black match box
thanks for the help, I tried it and it worked. black match box (GINO)
To head lights
