Bottom Seat Cushion Replacement
Old Dec 22, 2010 | 01:48 PM
tomringo's Avatar
tomringo
From: Richmond VA Everyone should have a VetteGuard
Default Bottom Seat Cushion Replacement
I'm getting organized to do a bottom seat foam replacement - drivers side. My leather is all good, but the cushion is getting flattened out. I have seen somewhere that there's the direct replacement foam, and also a thicker or more firm replacement anyone have any feedback on either and/or any info on which might better? Also I thought there was a vendor on the forum who sells the foam seat cushions, anyone have that name. Lastly and more importantly when doing this project were you presented with any surprises or things you found out that I should be aware of that could make this go smoothly. Thanks
Old Dec 22, 2010 | 01:53 PM
Gitusum's Avatar
Gitusum
i got my foam from a vendor here that does leather cover packages but cant remember the name but know the foam is nice and pretty reasonable but far as the swap it was pretty easy
Rick
Old Dec 22, 2010 | 01:56 PM
You can get some replacement seat foam from Matt at Vette Essentials. Good quality stuff and a fair price.
Old Dec 22, 2010 | 02:05 PM
RedSoxFan's Avatar
RedSoxFan
Matt at VE is a great guy and has the best price on OEM foam. I believe DJ Motorsports is the vendor that offers the firmer seat bottom foam, also for a very reasonable price.
Old Dec 22, 2010 | 02:28 PM
TraceZ's Avatar
TraceZ
Matt is the man. Call him first, he'll hook you up.
I got mine from Matt. It was less expensive to get a passenger side foam and use that in the drivers seat. The only difference between the passenger side and driver side bottom foams are the 2 quarter-sized holes in the foam for the child seat anchors. No big deal, the leather covers up anyways and you'll never notice.
Matt will explain it better than me. The price was really reasonable too, like half the price I saw anywhere else.
Old Dec 22, 2010 | 03:20 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Yep, DJ Motorsports offers a firmer seat foam than the OEM option. I asked them earlier it if they also plan to offer an alternative for the seat backs, however although planned, nothing has been made available (yet). Here is the link:
http://www.shop.djmotorsportaccessor...2&categoryId=7
I remember reading an earlier thread where a member also cut out a square piece of dense memory foam to fit into the square section at the bottom of the seat to help provide additional support and rigidity.
Another tip is to use trimmed burlap or a trimmed rubber/foam yoga mat to cover the springs before applying the foam. That prevents the springs from working their way though the foam over time.
Old Dec 22, 2010 | 04:33 PM
SaberD's Avatar
SaberD
i got mine from gm parts house. just make sure to put some kind of plate between the foam and the wires underneath the seat so they dont cut through the foam.
Old Dec 22, 2010 | 04:54 PM
TraceZ's Avatar
TraceZ
Yup, I cut up one of my wife's old yoga mats and put a square between the foam and the springs on each seat. It firmed up the seats a bit too.
Old Dec 23, 2010 | 12:41 PM
rbrtclk's Avatar
rbrtclk
When you change the foam, go get som burlap and glue it to the bottom of the new foam. This keeps the springs form cutting into the foam.
Old Dec 23, 2010 | 01:44 PM
ahphares's Avatar
ahphares
I just installed the firmer seat foams in the passenger seat as a trial. Turned out to be way to firm for my wife and myself. The vender gladly took back the unused foam. The foam that I installed was not returnable due required modification to provide relief for seat adj. switch panel. The OEM had right and left versions with the relief molded in, current replacements are a single foam that have to be modified for right and left.
Andy
Old Dec 23, 2010 | 05:08 PM
tomringo's Avatar
tomringo
Great info thanks to all.
Old Dec 24, 2010 | 11:28 AM
416 Rigby's Avatar
416 Rigby
Default The DJ foam is the ticket, but--
Be sure before you button the whole thing up that you have trimmed enough to allow the plastic housing for the seat adj switch to fit on. The firmer foam and any stuff Ya put over the springs makes the cover fit very snug, this makes it a bit of a trick to get the flimsy plastic switch cover on. If Ya force it the post in the front will break off either when you are putting it on or soon after.
I also used a big curved needle and very strong thread (125# braided fishing line) to attach the spots that org had the "hog rings". With a couple of passes of line thru the holes it allowes ya to pull on the ends to draw it up tight then tie it off. With the tight fitting cover ya don't have enough hands to use the rings, I also think there is less chance of tearing out the holes in the cover.
Old Dec 26, 2010 | 05:13 AM
tomringo's Avatar
tomringo
[QUOTE=416 Rigby;1576310253] The firmer foam and any stuff Ya put over the springs makes the cover fit very snug, this makes it a bit of a trick to get the flimsy plastic switch cover on. If Ya force it the post in the front will break off either when you are putting it on or soon after.
Sounds like I may be better off with the standard foam (OEM) vs. the thicker material for both fit and comfort. Thanks for the tips.
Old Dec 26, 2010 | 05:57 AM
Mr. Clean's Avatar
Mr. Clean
I recently bought the complete driver's seat foam from Matt at VE. I had the foam replaced by a local upholstery shop who also replaced two of the vinyl sections in my seat back. I was lucky because the stitching was tearing through the vinyl, but not the leather. I also purchased a new plastic switch trim panel because the plastic pin had broken on the original one. That was replaced at the same time. The upholstery shop also installed a piece of thin carpeting between the bottom of the foam and the springs.
Additionally, I provided some plastic tubing which I slit and the shop installed that over the outer edge of the back frame when they installed the new foam on the upper portion of the seat.
I was amazed at how comfortable the seat was after the foam replacement. The entire job cost me $450 including the seat foam, plastic trim plate and the bill from the upholstery shop.
2001 Pewter Convertible
Last edited by Mr. Clean; Dec 26, 2010 at 06:03 AM. Reason: Additional information
Old Dec 26, 2010 | 07:17 AM
wascapsfan's Avatar
wascapsfan
I added seat heaters when I removed my skins. I also repaired that slight rocking motion while I had the seat removed.
Seats are toasty now
Old Dec 26, 2010 | 08:04 AM
vafirevet's Avatar
vafirevet
i installed the "firmer" version without an issue. Fit is great and I just trimed the foam to make the switch fit tight. I like the firmer seat and theseat heater too!
Old Dec 26, 2010 | 08:32 AM
yaknow's Avatar
yaknow
Good info
To Bottom Seat Cushion Replacement
Old Dec 26, 2010 | 08:43 AM
rws.1's Avatar
rws.1
this is one of this winter's projects. thanks for the thread
Old Dec 26, 2010 | 10:14 AM
JohnsC5's Avatar
JohnsC5
I just installed the seat foam from DC Motorsports and kept the stock seat cover. One of the most comfortable mods I've done. It is firmer than the stock foam, but I like it.
Old Dec 26, 2010 | 10:36 AM
MSG C5's Avatar
MSG C5
Can you elaborate on the plastic tubing that you used (pics)? When I take mine apart, I want to make sure I use all the tricks to prevent the new foam from tearing, etc.
