oil was changed , and tryed to reset , back to 100%
car is a 2003 z06 aprox 50 thou miles ..i reset it many times
this time is just stays and still get change oil code . any ideas ..?
You must be using the reset button on the DIC (?). It takes more than a quick push of the button to reset to 0%.
The other manner which is more positive is to turn the key to on without starting the car. Then pump the gas pedal three times in quick succession. That's worked well on GM cars since the '90s.
thank you sir problem resolved 3 times on peddle who would have thought ..
