ebcm repair
Old Jan 19, 2011 | 09:52 PM
cruiser98's Avatar
cruiser98
1st Gear
Default ebcm repair
What is it with the 98 EBCM by delphi. Sent mine to be repaired twice and still getting error codes and dash lights. Also while driving it seems to apply brakes as if the car were in a spin or over steer/understeer, Anybody have any ideas on getting a new one or getting this rebuilt. Many shops only do the 2000 and up.
Old Jan 19, 2011 | 10:18 PM
Carcass's Avatar
Carcass
Corvette Salvage rebuilds the early modules,but "It not be cheap":
http://corvettesalvage.com/index.php...x&cPath=65_178
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
That is because you have Active Handling - JL9 Feature and more than likely your ABS Module is 9376711 or as GM calls them "Brake Pressure or Control Modulator Valve" (ABS & Traction Control)
"ONLY" the 2001-2004 EBTCM's can be 'Repaired' - unfortunetely the 1997-2000 EBTCM's cannot - so whoever said they could well.....
Is your EBTCM located up front on the Vette or in the rear?
You can interchange any of the Modules that are "ACTIVE HANDLING" JL9 feature (A/H) in those years but not any of the NON-Active Handling Modules (JL4 Non A/H)-
I have a 1998 with NON-Active Handling (JL4) and I can use any of the 1997-2000 modules but I cannot use a module from one of the Vettes that have A/H.
I have all the interchangeable module numbers for the NON-Active Handling modules but not for the Model you have.
You will have to find one with the A/H used, what is the number on the module?
You can also call GM, like I did, and give them your number and ask what part numbers (ALL Part numbers that superceeded yours) are interchangeable!
"IF" it turns out you have the Non A/H (JL4) like mine let me know and I can give you all the cross part numbers
Thanks,Matt
Old Mar 8, 2011 | 12:24 AM
theseal's Avatar
theseal
Default backdate z06 ebcm and abs module into 99?
my 99 is ALL front brakes. temps hit 500, rears only 320 or so...
my 03 z06 works all 4
seems simple enough concept to swap ebcm and bpmv and run the hydraulic lines into the new unit.... is this as simple as that or are their other issues?
Old Mar 8, 2011 | 10:32 AM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Won't work no way.
Who did you use for repair?Was it these guys?
http://www.bba-reman.com/
Been waiting for some feed back on these guys,
http://forums.corvetteforum.com/c5-t...post1576873288
Now just because you have codes doesn't mean the module is bad. What code #'s? Have you gone throught the grounds and wiring? From what I read the grounds are the #1 reason for EBCM codes.
Old Mar 8, 2011 | 10:35 AM
Redeasysport
Thanks,Matt
I think you are a little confused Matt you have the numbers reversed JL4 IS A/H JL9 is not.
Old May 27, 2011 | 11:38 AM
pontiacmike504's Avatar
pontiacmike504
Navigator
does anyone have a lead on who made this product for general motors, there has to be a outside source
Old May 27, 2011 | 11:48 AM
03WhiteConv's Avatar
03WhiteConv
Is your car lowered or have non-oem sized wheel/tire combo? Don't know about the 98's but others have had problems when the rake of the car changes. It doesn't take much to mess things up.
Old May 27, 2011 | 11:49 AM
Redeasysport
Bosche made them and doesn't have anymore or make them. Still waiting for someone to report a reliable repair source for the pre '00 cars.
Old Jul 14, 2011 | 02:09 PM
madmatt9471
This just may be a "LAST" resort for many of us - these are becoming more and more rare to find by the hour!
Thanks for the link - I am going to also forward it to individuals that need it for our 1997-2000
Thanks,Matt
To ebcm repair
