Lost all keys! Now what?
Old Jan 31, 2011 | 01:37 PM
flynbyu2's Avatar
flynbyu2
St. Jude Donor '10
Originally Posted by Mr.Bill
Just in case, I saw an ad in the FS section for a complete lock set for door, Glove box, Console and ign all keyed the same.
Mr.Bill
Outstanding! That's what makes CF the best!!!
Old Jan 31, 2011 | 01:38 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Originally Posted by a401cj
bad news...picked up the new key today and it doesn't open the door. The door lock (at least) has been changed. I guess I'll call the locksmith and see if he can open it w/o breaking the window. I really don't want to break the window. Then HOPEFULLY the new key will work in the ignition.
You can unlock the door with a coat hanger, The C5 is really easy to get into.
Old Jan 31, 2011 | 04:28 PM
The car should have only came with one key for all needed locks/ignition. If your's had two, then somewhere along the line someone must have changed out one of the locks.
Old Jan 31, 2011 | 08:35 PM
a401cj's Avatar
a401cj
8th Gear
thought I'd be smart and I found an old dipstick that fit down between the glass and weather stripping perfectly (yeah I wiped the oil off). The dipstick was bowed just right too. I hit the unlock button without any problem at all but the only outcome was that the horn started honking. No door unlock. Crap...
Fortunately it timed out after about 1 minute
Old Jan 31, 2011 | 08:38 PM
Mr.Bill's Avatar
Mr.Bill
The question is, Does the key start the car?
Old Jan 31, 2011 | 08:44 PM
a401cj's Avatar
a401cj
8th Gear
boy do I feel like a dumbass. The door DID unlock and the key works in the ignition too.
GITUSUM rules!
Thanks for the advice man!
BTW...dipstick from an old AMC V8 is PERFECT for this job if you're ever locked out. No window prying no nothing
Old Jan 31, 2011 | 08:47 PM
Mr.Bill's Avatar
Mr.Bill
GITUSUM rules!
So how come the key didn't unlock the door the first time?
Old Jan 31, 2011 | 09:16 PM
killain's Avatar
killain
Oldtimer
Default Key, what key ?
Please, the drama is killing me. It's like someone tore out the last pages of a good novel. "People want to know" Do we have a happey ending or ?
It just goes to show you the magnetism for good logically know how this forum can produce. If you've got a problem, we've an answer.
Old Jan 31, 2011 | 09:21 PM
AntonioZ06's Avatar
AntonioZ06
my first guess is probably it. Previous owner had a key made with the improper VATS pellet and could only use it in the door.
a401cj's Avatar
a401cj
8th Gear
apparently the door cylinder was changed prior to my ownership. It seems to be an older type cylinder. The ignition key won't even fit in it. It had a GM style key but the head was smaller. It's funny because nothing ever lead me to believe that anything was tampered with on this car. I usually have a nose for that but not this time.
the key that GM cut for me off the VIN works perfectly in the ignition
Next up is getting the right cylinder for the door and putting that in. I'll use my FOB (provided I can find it...wasn't inside the car like I thought) to lock and unlock in the meantime.
Thanks guys. Great bunch here.
