I'm in the market for a C5 Z06 and to date have only taken one out on a test drive. This car was an '01 with about 80,000 miles and beging offerred for sale at the local used car lot where it had been bought at auction.
The shifting was very stiff on this car - all gear changes. From 1st to 2nd was very stiff. It never missed a shift, but I had to use much more force than I expected. I'm comparing the ease of shifting to an older Porsche and a 2004 Mustang GT my father has. Also, the stiffness was there at low and higher RPM's.
I searched the forum, but cannot tell if this stiffness is normal. Also, if it's not, what would be the likelihood that a PPI on a car bought sight unseen would catch any transmission gear/synchro problem?
The GM 6 spd shifter shifts easily.
However it's well documented of having problems @ high rpm shifting from 2nd to 3rd.
Being that the Z you drove used more force/energy to shift, leans towards the shifter being an aftermarket.
When I switched from stock to Hurst, The missed 2 to 3 went away.
However it takes more force/energy to shift to all gears including
reverse.
I wouldn' let this be a deal breaker.
The dealer/person selling the car could have the shifter exposed, to see what model/make it is.
A competent machanic could check that out start, to finish in aprox a half an hour.
Good luck.
...The shifting was very stiff on this car - all gear changes. From 1st to 2nd was very stiff. It never missed a shift, but I had to use much more force than I expected. ... Also, the stiffness was there at low and higher RPM's....I searched the forum, but cannot tell if this stiffness is normal.
There is a Sticky on the Autocross Forum by Zenak that talks about replacing the POS C5 Z shifter with one from a C6 Z for about $200.
As dbaker mentioned, a lot, but not all, stiff shifting problems can be fixed with a tranny fluid change. In general, before anyone spends money on a tranny repair, I'd recommend taking this low cost option as a first step.
In the 01 you test drove, entirely possible it is running the stock tranny fluid, which shears down pretty fast. The stock tranny fluid in my 06 CTS-V lost 40% of its viscosity in just over 10k miles. At 80k, who knows how the fluid in the 01 you test drove is doing.
I agree that the fluid may need to be changed. I always used the stock shifter in my C5s and never had an issue with missing shifts or hard shifting. The shifter has a little stiffer and longer throw than an 08 C6 tranny but it isn't bad. You should be able to put your palm on the top of the **** and shift with 3 fingers and a push of the heel of the hand along with some arm movement to get to all gears. Don't grab it with your fist sideways or you will screw up the shifting.
