$2,000 brake job.
Old Jan 31, 2011 | 12:11 PM
mooney201's Avatar
mooney201
Default $2,000 brake job.
I just got off the phone with our local Chevy dealer, and they said when changing the brake pads you also need to change the rotors. They also said that a tune up which includes, spark plugs and wires along with the brakes, would cost $2,000.
This seems high to me.
I recently purchased the car with 62k miles on it, and was told the brakes have never been touched by the previous owner. I understand the spark plugs are supposed to last 100K miles, but this seems high to me.
As of now, the brakes and engine run fine.
Old Jan 31, 2011 | 12:12 PM
MawneeC5's Avatar
MawneeC5
Ack! Find a new dealership!
Old Jan 31, 2011 | 12:17 PM
corvette8189's Avatar
corvette8189
Diy
Old Jan 31, 2011 | 12:18 PM
AntonioZ06's Avatar
AntonioZ06
holy crap. I've seen some pretty bad dealer overcharging, but WOW.
Steer VERY clear of that dealer. If you only care about stock replacement parts, rotors and pads are only around 200-300. I would also ask to see what their "tune up" involves in writing. Even if you got new spark plugs, wires, all new filters, oil change, and battery it still would only cost MAYBE 200 bucks. You need to ask them where the other 1,500 is coming from!!!!
Old Jan 31, 2011 | 12:26 PM
dougbfresh's Avatar
dougbfresh
Really-$400-500 for everything if you do it. Bothe relatively easy jobs.
Old Jan 31, 2011 | 12:39 PM
Vettmann17's Avatar
Vettmann17
I think 2K is on the high side for a full brake job w/plugs wires and oil change. Shop around for the brake job, you'll get it done for a lot less, however make sure the parts being used are premium parts, after all you get what you pay for. If you car is running well then you can certainly wait to do the plugs/wires. I do think you'll be hard pressed to get a quality brake job done for a few hundred bucks and no way will you get new plugs, wires, oil, filter and battery for 200.00, I don't care where you bring it to. Find a reputable shop or dealership and get the job done right with the right parts and get it done right the first time. Sometimes you try to save a few bucks here and there and it winds up costing more in the long run. Good luck bro!
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
When replacing brake pads, you should have a true and fresh friction surface......that being said and depending on the condition of the existing rotors (thickness), they can be turned. They should be turned or replaced.
As far as plugs, at 62K miles - I would change the plugs. Yes they are supposed to last 100K, but reality is I would change the plugs.
We use NGK TR55's - they cost about $3 apiece. GM Hot Wires (red) are about $80.
Alldata which is the flat rate book most places use calls for 2.1 hours on the plugs, wires are 2.5 hours. Brake pads and rotor replacement is about 3.8 hours. I don't know what the dealership's hourly rate is - let's just say it's $100 per hour - that's $840 labor. How much are they charging you for new rotors and pads?
Old Jan 31, 2011 | 12:40 PM
dankhts's Avatar
dankhts
that's probably right for a stealership, considering they use genuine parts at full list price! you've actually onl;y got about a hunnert bux worth of plugs and wires and about 4 hunnert bux worth of pad/rorors if you get some nice slotted/drilled with ceramic pads.....3 - 4 hrs labour should cover everything..... I've done it all in less....
Old Jan 31, 2011 | 12:44 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Is it possible part of that huge number is based in California's high cost of living?
Old Jan 31, 2011 | 12:45 PM
Bigcountry7's Avatar
Bigcountry7
If you want to do it right. You should definitely replace the rotors and pads if neither have ever been touched. Not sure about the tune up but since the age of the car is almost 10 years old it isn't a bad idea. If you don't want to spend the money now you don't have to. You should shop around and be able to find someone that will do it alot cheaper than the dealership.
Old Jan 31, 2011 | 12:52 PM
AntonioZ06's Avatar
AntonioZ06
not really. I live in NJ, which is equally high
If you don't feel comfortable with handling these tasks yourself, you could order all those parts from Gene Culley for my estimated $500 (the battery from a store of course) and then bring it to a local performance shop (preferably one that does lots of vette work) and they could probably do it for you for WAY less than the 2,000 quoted to you.
Old Jan 31, 2011 | 12:53 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
I never in my life heard of replacing rotors with a pad replacement.
If they are bad you can turn them, if they aren't put pads on and drive away.
I suppose they would tell you to replace the windshield when you replace wiper blades.
Old Jan 31, 2011 | 12:55 PM
damilleniumboy's Avatar
damilleniumboy
God damn! That is a bit pricey. For that money you can get a set of C6Z calipers lol. There are plenty of DIY in this forum. Do a search and save $2000.
Old Jan 31, 2011 | 12:57 PM
robert miller's Avatar
robert miller
Originally Posted by corvette8189
Diy
Man do it yourself here, are get a good local shop to do.
Old Jan 31, 2011 | 01:11 PM
VinnyT's Avatar
VinnyT
I hope they throw in a "lube" job for free......
Old Jan 31, 2011 | 01:29 PM
n8dogg's Avatar
n8dogg
$2000 is very high for just brakes and plugs/wires. Are you sure there isn't something you have missed.
According to Alldata:
Parts:
Front Rotors: $92x2= $184
Front Pads: $143
Rear Rotors: $92x2= $184
Rear Pads: $102
Total Parts Cost: $613
Labor:
Replace Front Pads: 1.4hr
Replace Front Rotor (one side): 0.2hr X2= 0.4hr
Replace Rear Pads: 1.4hr
Replace Rear Rotor (one side): 0.2hr X2= 0.4hr
Total Labor Time: 3.6hr@ $85 per hour (average labor rate)= $306.
Total brake job= $919 parts and labor. Don't forget to add tax.
So that $1000 to change spark plugs and wires.
Alldate shows 2.1 hours time to replace plugs. Plugs shouldn't cost more than $70 at GM list. $250 should cover spark plug replacement. No reason to change the wires at this point.
Old Jan 31, 2011 | 01:33 PM
Choreo's Avatar
Choreo
First time around I bought my own rotors and pads and took them to my Dealership to install. They charged me $350 labor.
To $2,000 brake job.
Old Jan 31, 2011 | 01:35 PM
flynbyu2's Avatar
flynbyu2
St. Jude Donor '10
Are you sure you didn't make a down payment on a Chevy Volt?
I'll tell you what, you bring it to me, I'll do it for $1500.
Daddyrama31's Avatar
Daddyrama31
High for sure. Find another dealer or better yet DIY!!
Old Jan 31, 2011 | 01:37 PM
PETE O.'s Avatar
PETE O.
When you buy a C5 you'd better figure on working on it yourself, unless you're rolling in cash. These little gems are expensive to drive. Most all maintenance is pretty easy if you have the proper tools. Not only that but it's fun and it brings you closer to your car and it's little idiosyncrosies.
