transmission cooler?
Old Jan 31, 2011 | 05:25 PM
timritchieblue's Avatar
timritchieblue
Default transmission cooler?
what size cooler you guys running? looking at a few different ones
http://cgi.ebay.com/ebaymotors/B-M-7...item3f0218c536
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
im liking the last one?
Old Jan 31, 2011 | 05:35 PM
02*C5's Avatar
02*C5
What I would do is set yourself up with 2. The first set it up in your bumper behind the Corvette plate cover get a screened one 11X8 should fit with no issues. The second set it up in front of your condenser 11X11. Rout the hoses from the first to the second and it will keep your tranny very cool. Fans are only good when you are stopped thats all.
Also use CASE tranny fluid has a heat index of 500* instead of the 300* of the dextron and will give your tranny a longer life. If you over heat it wont air-rate like the dextron will.
good luck
Old Feb 19, 2011 | 04:35 AM
mickey_7106's Avatar
mickey_7106
good luck
they wont work when the car is rolling?
Old Feb 19, 2011 | 08:57 AM
timritchieblue
i went with a b&m stacked plate super cooler, should be finished Monday
Old Feb 19, 2011 | 12:05 PM
mickey_7106
let me know how it works out for you? im not sure wether to get the B&M with the fan or the Hayden with a fan
Old Feb 19, 2011 | 12:35 PM
timritchieblue
my installer said this will work just fine
B&M 70264 SUPERCOOLER AUTOMATIC TRANSMISSION COOLER
$59.99
Old Feb 19, 2011 | 12:37 PM
damilleniumboy's Avatar
damilleniumboy
Good post; I will need a tranny cooler once I get a new tranny. My 3-4 clutches are fried.
Old Feb 22, 2011 | 08:51 PM
Dale002's Avatar
Dale002
$59.99
If you don't use ms fittings on the hoses it will leak at the connections. Water hose clamps are not the way to go.
Old Feb 22, 2011 | 10:03 PM
timritchieblue
trans temp got to 173* highest its got for 120 miles, will check for leaks
Old Feb 22, 2011 | 11:09 PM
02*C5's Avatar
02*C5
Yes they work, I didn't meant they are not turning, but fans are good only when the car is stopped and there is no air moving through the coolers because of air velocity. If your car is moving faster than the fans move air I guess the fans aren't doing much.
Old Feb 23, 2011 | 07:17 AM
crosstheline's Avatar
crosstheline
$59.99
Installed a Dewitts w/no transmission cooler and put the largest B&M cooler (cooler alone was $89.00) in along with stainless steel, crimped fitted lines on mine. I wouldn't trust those rubber lines.
Old Feb 23, 2011 | 09:15 AM
Dale002's Avatar
Dale002
Old Mar 2, 2011 | 12:24 PM
craigyboy's Avatar
craigyboy
Where did you install this? and do you have any pics of the install?
Thanks Craig UK
Old Mar 2, 2011 | 01:54 PM
timritchieblue
mines right in front of the rad, plenty of room
Old Mar 12, 2011 | 01:53 PM
TNRAT's Avatar
TNRAT
Installed the B&M 70264 yesterday. I took it on a 40 minute drive in stop & go traffic and it never got over 160. I drove the same route 2 days before and it hit 193. Only difference was outside temp was 13 degrees cooler yesterday than 2 days before.
We removed the OEM cooler lines to the radiator so just the B&M is cooling the trans.
Old Mar 12, 2011 | 01:59 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Sorry to take this in another direction but I would be remiss in not noting Timritchieblue's avatar. Stunning.
Okay.....now back to substantive discussion.
Old Mar 12, 2011 | 02:07 PM
TNRAT's Avatar
TNRAT
Fits right into the discussion about hot and cooling...
To transmission cooler?
Old Jun 19, 2011 | 11:02 AM
TwoValveKid's Avatar
TwoValveKid
Ok ive been searching all morning and maybe im being too specific. Anyone know that quick disconnect fittings on the cooler? Im looking to put a cooler on soon and use the stock lines and i remember finding the connector type before.
Old Jul 10, 2011 | 06:52 PM
Humy's Avatar
Humy
where do you buy these lines? or MS fittings?
Old Jul 10, 2011 | 07:24 PM
Blow Torch's Avatar
Blow Torch
What about your "in town" temps? My highway temps are fine because the TC is locked and not slipping, but around town on a 98* day it's a different story.
I went with the larger 274 because I was a little afaid the smaller 264 might not be able to handle the heat in town.
Did you bypass the rad?
