Brake flush
Old Feb 1, 2011 | 01:36 PM
HERK's Avatar
HERK
Default Brake flush
I am going to flush out my brake fluid .How much new fluid will I need?
Old Feb 1, 2011 | 03:08 PM
bob guzzy's Avatar
bob guzzy
Buy 2 quarts and that should give you plenty to do the brake and clutch.
Advanced Auto have a decent price on Valvoline Synthetic brake fluid.
A day or so before you do the cleaning, suck out the fluid that is in the master and replace it with new stuff then drive around a little, it helps clean up the master, then suck that stuff out and put new stuff in then do your flush.
If you don't have anything to suck out the fluid, take a trip to a drug store and get an enema syringe, buy the larger one, I have had the same one for years using it on all types of fluids, just add a small piece of hose, to get down into the master.
Old Feb 1, 2011 | 04:11 PM
HERK's Avatar
HERK
Thanks for your help.
Old Feb 1, 2011 | 04:20 PM
dbaker's Avatar
dbaker
Check out Rangers clutch care.Some of the best info on CF.Also get some speed bleeders valves.Saves lots of time.Rockauto.com has them made by Dorman.
http://www.rangeracceleration.com/Clutch_Care.html
\db2
carolina
To Brake flush
