speedometer changes with upsize tires
Old Feb 1, 2011 | 08:44 PM
bethunsl's Avatar
bethunsl
Default speedometer changes with upsize tires
I just put an 18/19 wheel and tire package on my 02Z. Looking at the old and the new tires it's a little taller. A friend told me that the computer automatically makes changes to adjust speedometer calibrations. I think that the changes have to be loaded with a programmer or a tune . Can anybody shed some light on this or is it not enough of a difference to bother with it.?
Old Feb 1, 2011 | 09:12 PM
YeloFevr's Avatar
YeloFevr
Nope, you're fine. The vehicle speed sensor is located on the differential.
Old Feb 2, 2011 | 10:24 AM
Russ K's Avatar
Russ K
What size tires are on the rear now?
Russ Kemp
Old Feb 2, 2011 | 11:29 AM
bethunsl's Avatar
bethunsl
Old Feb 2, 2011 | 11:55 AM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Yeah, it's counting rotations - HOWEVER, one rotation will now move you farther - thus faster. In the programming, you need to put in the new rear tire size. That will fix the calibration. It will NOT fix itself.
Old Feb 2, 2011 | 11:59 AM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
As long as the ratios are the same between the old and new you'll be fine but it's not only the speedo you have to worry about it's the traction control. I have winters on the fronts and backs and the front's are slightly larger than the factories so when I floor it the traction control kicks in but if I turn the TC off then it's fine, no big deal, but just something to be aware of.
Old Feb 2, 2011 | 12:02 PM
doje's Avatar
doje
You are correct that a bad ratio will cause TC issues. However, even if the ratios are correct, a change in tire height will cause speedo miscalibration issues.
Old Feb 2, 2011 | 12:10 PM
bethunsl's Avatar
bethunsl
So it looks like the thing to do is to get a hand held programmer and put the new tire sizes in while dialing up the power or take it to a tuner and have it done.
Old Feb 2, 2011 | 12:11 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Figure out the circumference of the old and new tires, if they are very close to the same then there is no issue.
Old Feb 2, 2011 | 12:14 PM
themonk's Avatar
themonk
So for argument sake all the tires are the same size and you go from a 275/40/18 to a 285/35/19 the speedo will be out?
Old Feb 2, 2011 | 12:22 PM
Zilla's Avatar
Zilla
Here is the calculation for the tire size you put in your post
275/40/18
tire diameter -26.661
Tire Circumference - 83.758
285/35/19
tire diameter -26.854
Tire Circumference - 84.364
The circumference is out by a half inch so the speedo will not be effect that much not enough to be worried about.
Old Feb 2, 2011 | 12:23 PM
steve8's Avatar
steve8
Plug in anything you want to find out.
http://www.miata.net/garage/tirecalc.html
Old Feb 2, 2011 | 12:29 PM
pluslt's Avatar
pluslt
You could just borrow someone's GPS if you do not have one and go for a ride. The GPS will tell you how fast you are going. I found mine to be pretty accurate across three cars so I have no reason to believe it can't be used to tell you if your speedo is now off or if its still tracking correctly. From there decide what you want to do.
Old Feb 2, 2011 | 12:46 PM
doje's Avatar
doje
275/40/18
285/35/19
with the tires being so close in height, you will only be off by about 1/2 mph at a speed of 80 mph. Nothing I would worry about.
Old Feb 2, 2011 | 02:10 PM
CBILLY1's Avatar
CBILLY1
The "right way" to make sure the speedo and odometer are correct is with a hand held programmer like the GM Tech II. You program in your current tire size and the computer does the rest.
Old Feb 2, 2011 | 02:15 PM
themonk's Avatar
themonk
that's what I use.
Old Feb 3, 2011 | 06:43 PM
bethunsl's Avatar
bethunsl
Thanks for the input guys.
To speedometer changes with upsize tires
